LM386 Audio Amplifier
Intro: LM386 Audio Amplifier
I wanted to design an audio amplification circuit for a future project so i just wanted to design this one for now so i get an understanding of how it works. This is a very basic circuit that you can find all over using an LM386 integrated circuit i got from RadioShack.
STEP 1: Obtain Parts
All Components can be found at RadioShack.
Multipurpose PCB with 417 Holes
5-15 Volt DC power supply (4 AA or 1 9v Battery)
8 Ohm Speaker
Audio Source e.g. iPod
8-Pin Retention Contact
IC1 IC LM386 Audio Amp IC
R1 Resistor 10 Ohm
R2 Resistor 1K Ohm
R3 Potentiometer 10K Ohm
R4 Resistor 10 Ohm
C1 Capacitor 220 Micro Farad
C2 Capacitor 10 Micro Farad
C3 Capacitor 220 Micro Farad
8 Ohm Speaker
R1 Resistor 10 Ohm
R2 Resistor 1K Ohm
R4 Resistor 10 Ohm
STEP 2: Place Components
Arrange components the best you can using the wiring diagram. i placed them as close together as i could, but it may be easier to spread them out a little more or breadboard this circuit first. I highly suggest breadboarding first just to get a feel of the arrangement, prior to soldering.
STEP 3: Observe Diagram
Look through the wiring diagram to see what components need to be connected to what prior to soldering. This is a basic wiring diagram, one of a hundred I found online, very basic. The one i used was from this website http://www.rason.org/Projects/icamps/icamps.htm.
STEP 4: Solder Components
Solder components carefully to ensure there are no shorts, also ensure all connections are made at all points.
STEP 5: Clean Up and Test
Trim component leads and clean solder joints. Be sure to double check connections to make sure a connection isn't left out. Hook up a 5-15 Volt DC power supply, your audio source, and 8 Ohm speaker and test it out. Be sure to ground out the audio sources audio low line and ground out the speakers ground wire to the circuits ground.
168 Comments
hkeating1122 11 months ago
my lucky number is 13 3 years ago
JamesJ 2 years ago
Joe3502 7 years ago
Jimbo724 4 years ago
Did you try using the nte823? It's supposed to be a direct replacement for the LM386. Did it work well enough?
Jim
deepu9422 7 years ago
How do i make it for 2 speakers(L & R) ,Do I have to make 2 of them?
Zeeshan gohar 7 years ago
patrickjane79 7 years ago
hii ..can you suggest a different ic tht can produce a 1-2 watt output
pruthvi-in-instructs 8 years ago
can I use a 2W speaker?
Quirc 7 years ago
Yes, you can.
Quirc 7 years ago
Just a little question, the R4 resistor wasn't supposed to be placed before C3? I mean, at some point, the 220uF electrolytic will charge and won't allow the current to flow, right?
vivster13 8 years ago
This may be a dumb question but where do i connect the battery's positive and negative terminals specifically?
to pin 4 or 2 any ony might work
JGUZMANO 8 years ago
great and simple amp. Thanks for sharing. Room for probably a stupid and repeated question? How much current / power could this amp drive?
Umair.360installer 8 years ago
Capacitor 220 mF 25v?
PranavH1 8 years ago
trax_e_rev 8 years ago
chris.dwyer.1238 9 years ago
Quick question, and hopefully not a stupid one. How do I connect the audio input to this circuit? What kind of cord should I use? I have tried using a 2-wire cord and grounded the black cord, using the red as the input. That gave me some sound with lots of garbage. I spliced a set of earbuds and have a red, black, and green wire. Would this work? Please somebody help!
