Ladder Converted Into a Bookshelf
Intro: Ladder Converted Into a Bookshelf
I made a bookshelf to stock your books and even other things. I made this because not everyone has the money to just go out and buy a bookshelf so I made this for those that need a quick and easy way of accessing a bookshelf. It is very sturdy and can hold lots of weight if designed correctly.
STEP 1:
For step one you will need to grab the ladder and the sandpaper go over the entire ladder with the sandpaper and stop when you feel the ladder is smooth enough.
STEP 2:
Step two is optional if you'd like to paint your bookshelf. If you do paint I would recommend painting with wood paint if you chose a wooden ladder, and wait at least 6-8 hours before continuing on to step 3.
STEP 3:
In the next step, you will need the Ladder, wall screws, and the drill. First, grab the ladder and put it up against the wall, and began screwing in the wall screws with the drill all across the ladder until the ladder becomes sturdy and eligible of holding weight.
STEP 4:
For the very last step, you stock your books on your brand new bookshelf designed at home by you.
