Introduction: Laminating a Cover for My Disc Sander
If your following this series this is part 2 of making a 12 inch 300mm disc sander,in this Instructable I'm laminating a "U" shaped Cowl to fit over the disc for dust extraction.
Step 1: The Disc
I've taken the faceplate of the disc and I'm using it has a former to bend the 2.5 X 50mm strips.
I have screwed 2 pieces of of 20x30mm either side of the disc and then screwed blocks to the outside of the disc spaced equally around the disc
Step 2: Taping Up
I've marked the board around the disc then taped up to protect the board from the glue.
the first strip was not glued to create a 3mm gap to the disc then i glued up with PVA glue the other 3 strips and bent them round the former.
Step 3: Clamping Up
I started clamping up from one side with spring clamps making sure that there was no gaps in the laminates and tapped them level.
Step 4: Realesing the Cowl From the Former
I left the laminate over night before taking the clamps off.
Please check out my video for a more comprehensive view of the build and give me a thumbs up
[Play Video]
