Introduction: Lampshade for Livingroom
About: Hey! My name is Roey Leon, from Tel Aviv, Israel. On my free time, as a hobby of mine, I love building stuff from scratch. It always starts with a crazy idea, and then I realize that it`s too Dangerous / Unach…
Hello Everyone
This little instructable took place at my house
The living room
Step 1: Build Process #1
Drive to the nearest wood store and buy the desired size and diameter of the Plywood
Cut it the size you want
Make sure the Plywood are smooth and good looking
Step 2: Cutting
Cut the Plywood you desired size
Step 3: Gather the Frame
Take the Plywood , and attach it to each other , so you have a nice shape like the one above
Strengthen it with Aluminum angles
Step 4: Strengthening the Structure
Strengthening the structure
Step 5: Create the Cube Shape
Attched the two square shapes together so you have a nice cube
Step 6: Attaching the Outer Cover
Take the outer shell and cut to fit the size of each rib
Take a clear and strong adhesive, and paste the cover on each side of caution
Step 7: Pasting
Paste the cover frame with adhesive tape
Just to keepmit tight
Step 8: Wrap the Whole Structure With Wallpaper You Desire
Take a wallpaper the color you want, and cut it to fit the ribs
attached it to the the ribs and make sure you stick it well enough
Cut the excedded wallpaper !
Step 9: Peal Off the Leftovers
Step 10: Prepare the Needed Materials for the Lighting Fixture
Step 11: Lighting Fixture Installation
Lighting Installation is pretty easy.
It needs to be on top of the lampshade , so you only see beneath the lights it self and not the structure
Step 12: Adding Chains to Hang the Fixture
I used very regular , thin chains to hang it .
Make sure it is tighten securely to the upper base of the fixture
Step 13: Hanging the Lampshade - Finally
