Laser Anemometer
Intro: Laser Anemometer
This instructable explains how to make an anemometer from an Arduino Uno R3, two VL6180X laser distance modules, and a section of plastic drain pipe or similar.
Processing3 is used to display the wind speed and wind direction.
The wind direction is independent of the pipe dimensions.
The sensitivity to wind speed depends on the pipe dimensions and the amount of applied damping.
Construction is simple ... all you need is a drill , a hacksaw, and a hot-glue gun.
The anemometer is purely experimental and is published in the hope that the techniques will be of use to others.
The estimated cost to build this anemometer is between $20 and $50 depending on how many parts you have on-hand.
Images
- The cover photo shows the anemometer construction
- Photo 2 shows the display
- The video shows the anemometer in operation.
STEP 1: Theory
The cross-section of a pipe is a circle.
The points at which the two laser beams touch the inside of a pipe define the end points of a chord on this circle.
The length of this chord varies when the pipe is tilted (photos 1, 2, 3)
Knowing the pipe radius it is possible to calculate the X and Y displacement of the pipe from which the wind speed and direction may be calculated (photos 3, 4)
STEP 2: Circuit Diagram
The anemometer circuit is shown in photo 1
Very few parts are required ... just the Arduino and two Vl6180X laser distance modules.
STEP 3: Construction
Step 1
(Photo 1)
- Cut one loop off the end of the 11/16” extension spring (I used a diamond file)
- Press the M4 nut inside the coiled spring
- Solder the nut through the spring ... the solder will not take to the spring but will prevent the nut pulling out.
- Push the other end of the spring down tube
- Fasten the spring in place using the self tapping screw. [1]
Step 2
(Photo 2)
- Cut 20mm from the bottom of an old credit card or similar.
- Cut the length to twice the height of a VL6180X sensor
- Lightly score the center and fold to 90 degrees
- Hot glue this plastic angle to the aluminium tube such that it will just be covered when the plastic downpipe (or bottle) is attached
Step 3
(Photo 3)
- Hot glue a VL6180X sensor to each of the plastic faces.
- Before doing this read Step 5: Calibration below
Step 4
(Photo 4)
- Drill a 5mm hole in the tube above the sensors
- Feed three pairs of twisted wires through the hole and out of the tube.
- One pair of wires is for VCC and GND
- The second pair of wires is for SDA and SCL
- Each of the remaining wires is attached to a sensor SHDN pin
Step 5
(Photo 5)
- Attach the pipe and end-cap
Step 6
(Photo 6)
- Mount the pipe vertically for testing [2]
Notes
[1]
- The amount of exposed spring determines the damping.
- If too much spring is exposed the tube will tend to oscillate much like a playground swing
- If too little is exposed the tube will require a large air flow before it will tilt.
[2]
- A multispeed hair-dryer is useful when testing.
STEP 4: Software
Step 1
(Photo 1)
Download and install the Pololu VL6180X library.
- Open your Arduino IDE
- Left-click “Sketch | Include Library | Manage Libraries
- Type VL6180 in the search bar and wait for the above screen
- Left-click "Install" to install the Pololu VL6180X library
Step 2
Install the Arduino Software
- Download the attached file “laser_anemometer_sender.ino”
- Using a text editor such as Notepad++, copy the file contents to a new Arduino sketch.
- Save the sketch as “laser_anemometer_sender” (without the quotes)
- Compile and up load this file to your arduino
Step 3
Install the Processing3 software
- Download and install Processing3 from https://processing.org/download
- Download the attached file “laser_anemometer_display.pde”
- Using a text editor such as Notepad++, copy the file contents to a new Processing sketch.
- Save the sketch as “laser_anemometer_display” (without the quotes)
Step 4
Testing
- Unplug your Arduino
- Connect the VL6180X sensors to your Arduino
- Reconnect your Arduino to your computer
- Open the “laser_anemometer_display” sketch
- Left click the top-left start-button ... a display similar to photo 2 will appear. [1]
Note
[1]
If you get a red error message click the Processing Stop button then click the Start button again.
The error message is harmless and appears if the input buffer has unexpected data.
STEP 5: Calibration
Step 1
Calibrating the sensors
- The VL6180X sensors are able to measure distances 1mm .. 100mm from the sensor.
- The data sheet indicates that this distance may be up to 15mm out ... I found mine to be around 11mm out.
- Instructions for calibrating each sensor may be found by reading the setup() notes in the Arduino file “laser_anemometer_sender.ino”.
- Once adjusted each sensor is able to measure distances down to 1mm from the sensor face.
- You will get a reading of 255 if an object is not detected.
- Photo 1 shows my test setup.
Step 2
Calibrating the anemometer wind speed.
The following steps calibrate the zero wind speed reading.
- Change code lines 52,53 to read
- const float North_offset = 0.0; // distance (mm) from centre-line
- const float East_offset = 0.0 ; // distance (mm) from centre-line
- Recompile and upload the Arduino code
- Run the Processing3 sketch ... the red disc will be extremely large
- Note the two right-hand numbers flowing down the processing screen
- Copy these numbers to the North_offset and East_offset in Arduino code lines 52,53
- Rerun the Processing3 code ... the red disc will now appear as shown in photo 2.
Possible methods for calibrating the moving wind speed, short of a wind tunnel, include:
- Take the anemometer for a drive on a still day with a friend noting the deflection at different road speeds ... this should work providing the road is flat and level. Once you have this data it's just a matter of adjusting the scale.
- Listen to / view your local weather forecast and note the pipe deflection for various local wind speeds over a period of time then adjust the scale.
Once the sensors have been calibrated it's just a matter of aligning the north-facing sensor due North with the aid of a compass. Be aware that True North is not the same as Magnetic North.
STEP 6: Summary
This instructable describes a laser anemometer made from an Arduino Uno R3, two VL6180X laser distance modules, and a section of plastic drain pipe or similar.
The anemometer is designed for land based situations ... it cannot be used on moving objects
The wind speed and wind direction are presented in graphics form
Adjustment procedures are provided.
Click here to view my other instructables.
38 Comments
isikli2000ibrahim 1 year ago
After running for a certain period of time I get this error message:
Processing 4 ->
Error, disabling serialEvent() for COM6
null
What is the reason for this error? How can I fix it?
lingib 1 year ago
How did we get the speed from the distance dx and dy we found?
What exactly is scale?
Shouldn't we divide the distance we found by time?
I didn't quite understand this part:
Windspeed = sqrt(sq(dX) + sq(dY)) * Scale;
lingib 1 year ago
tomsz2007 1 year ago
lingib 1 year ago
With regards to using a 3-axis accelerometer/gyroscope chip ... probably not.
In theory it should work but gyro drift is likely to be a problem.
Bez 2 years ago
stuck now. The laser is working but default address is 0x29.
lingib 2 years ago
The the default addresses of your VLX6180X sensors are automatically over-ridden when you install and run the "laser_anemometer_sender.ino" found in Step 4 "Software".
This is achieved as follows:
- Code lines 43, 44 contain the over-ride addresses.
- Code lines 94~96 shutdown both sensors to avoid address conflict
- Code lines 98~104 set the North facing sensor to 0x30 (Note ... this address does not conflict with 0x29 when the East-facing sensor is reactivated)
- Code lines 125~131 set the East-facing sensor to 0x31 (Note ... not necessary but done in case future sensors need to be added)
Bez 2 years ago
I can see the address change using the code.
I2C scanner. Scanning ...
Found address: 48 (0x30)
Found address: 49 (0x31)
Done.
Found 2 device(s).
Is it possible to change the address permanently?
lingib 2 years ago
See page 76 https://www.st.com/resource/en/datasheet/vl6180x.p...
Bez 2 years ago
It is working now just need to do the final assembly and calibration.
lingib 2 years ago
PierreArch 2 years ago
Your design got me thinking about a similar solution using load cells and flat panels. You may be interested to consult this web site...https://www.engineeringtoolbox.com/wind-load-d_177... as it provides math to extrapolate static pressure into wind speed.
Keep on making!
lingib 2 years ago
I guess time will tell whether dust and insects are a problem. At the time the contest was announced I had been experimenting with several different types of anemometer. It so happened that I had my "Laser Anemometer" working.
Thank you for your link to the wind-load website ... it looks interesting.
chdouvletis 2 years ago
It would be nice if you could try it in real world conditions.
Also, I suppose there is maximum speed it can measure, depending on the radius of the cylinder. Am I correct? Have you calculated this parameter?
lingib 2 years ago
With regards to the maximum speed, the pipe won't move if it is infinitely heavy or infinitely small, so there is no maximum ... it's just a case of finding a cylinder/cone that gives a suitable reading in your wind conditions and adjusting the length and damping to suit.
Good luck with your weather station ... let's know how you get on.
BerenV 2 years ago
ChrisWx 2 years ago
lingib 2 years ago
Let's know how you get on ... your project sounds interesting :)
joevangeaux 2 years ago
For instance, simply capping the "darg pipe" with a heavier, and possibly wieghted, one would give a higher range of readings for those hurricanes we get around here that has a nasty habit of ripping away the typical vane-type anemometers!
