Introduction: Laser Cutted Lamp - 3mm - Model 001
Hi, my name is Roberto and this is my first ceiling light obtained by cutting 3mm plywood.
Step 1: Skills Required
You also need:
- to be able to use Illustrator (or SVG software);
- to be able to be familiar with the Glowforge web interface (https://app.glowforge.com);
- be patient in the assembly of the individual pieces;
Step 2: What You Need
To make this lamp you need:
- Adobe Illustrator (or Inkscape or any software to elaborate SVG file);
- CNC laser (I used a Glowforge Basic but theoretically you can you any CNC);
- 3 sheets (or more) of 3 mm plywood;
- patience and creativity.
Step 3: Download and Edit the File
I used the TinkerFun file and modified it according to my needs.
If you want you can download/use the files that I modified: I changed the size of the top and bottom to match the neon and the bulb holder sizes.
Step 4: Upload the Files on Glowforge Web App and Set the Laser
My settings are:
- material: pine plywood 0.118 inches (3mm)
- laser speed: 190;
- laser power: full power;
- passes: 1;
- focus height: 0.118 inches (3mm)
Step 5: What Will You Get
When you have finished cutting all the pieces you will have:
- 1 top part (remember to check the dimensions of the hole for the bulb holder)
- 1 bottom part (remember to check the dimensions of the hole in order to change the bulb)
- 16 lamellae
Now you are ready to assemble the lamp
Step 6: Assembling and Gluing
Now you are ready to assemble your lamp.
The assembly is quite simple and if you want it does not even require glue (I didn't use it).
Just be careful because some parts are a bit 'delicate.
If you think to use the glue, first try to assemble it roughly to see that everything is ok, then unmount it, paste the joint jigs and assemble it again.
Done
Step 7: Resources - Sources - Links
I got this lamp inspired by the "Laser cutted Lamp" project of TinkerFun created on Nov 30, 2016 on Thingiverse.com
I thank them for inspiration and you for following my tutorial.
