Laser Tripwire Alarm
Intro: Laser Tripwire Alarm
No security system is complete without lasers. So in this project I am going to show you how to build a laser tripwire alarm from a laser point, a couple of mirrors, and a few dollars of electrical parts. With this you can cover an entire house with an array of light beams. If any one of them is crossed it sets off your alarm. It can be a standalone alarm or it can be integrated into a larger DIY security system.
STEP 1: Safety Note: Working With Lasers
Also never point lasers at aircraft.
STEP 2: Parts
Laser Pointer
Printed Circuit Board
555 Timer IC
IC Socket (optional)
3-12 Volt Buzzer
Switch
CdS Photoresistor
2 resistors
3 AA Batteries
3 AA Battery holders
Jumper Wires
Heat Shrink Tubing
STEP 3: How the Circuit Works
This alarm circuit is yet another way to use a 555 timer IC.
The light sensor that detects the laser is a CdS photoresistor (R3). This is wired in series with standard fixed resistor (R2). These two resistors form a voltage divider that is used to activate the IC. The value of R2 should be approximately the same as the resistance of the photoresistor when you are shining the laser pointer directly at the light sensitive face. Because the output characteristics of photoresistors varies considerably from one to the next, you need to measure it with a multimeter. So connect the photoresistor to the multimeter and shine the laser pointer directly at it. In my case, its resistance was about 100 ohms. So I used a 100 ohm fixed resistor for R2.
When the light beam is interrupted, the resistance of the photoresistor increases dramatically. As a result, the voltage at pin 6 also increases and goes above the reference threshold. This causes the output pin 3 to go LOW and activates the alarm.
To turn off the alarm and reset the system, a (single pole double throw) switch disconnects the speaker and sends the LOW signal from the output pin 3 to the trigger pin 2. The system is now deactivated. To reactivate it, flip the switch back to the original position. The alarm will remain off until the next time that the light beam is interrupted.
The supply voltage can be anything from 4.5V to 18V. I chose to use 4.5V (three AA batteries) because this is the same voltage that is used by the laser pointer. This gives you the option of powering the laser pointer with the same battery pack as the alarm circuit.
The resistor R1 acts as a pull-up resistor for pin 2. It helps to prevent false triggering from static electricity. This can be any value. In many cases it can be left off without causing any problems.
The alarm that I am using is a piezo buzzer. Any buzzer can work as long as it is rated to operate at the appropriate voltage.
STEP 4: Assemble the Circuit
If everything is working properly, solder it all together on a printed circuit board. The board that I used is a general purpose IC board. These are really convenient for circuits that are built around small ICs like the 555 timer. I also used an IC socket to attach the IC. This makes it easy to change out the IC but it is not necessary.
The batteries are mounted in individual AA battery holders. The three battery holders are soldered together in series and the end leads are soldered to the circuit board.
When attaching the photoresistor, I mounted it with the leads sticking out about one inch from the board. This makes it easy to make small adjustments to the position of the photoresistor after it has been mounted in place.
Once the whole circuit is soldered to the board, test it again to make sure that everything is working properly.
STEP 5: Secure the Loose Parts to the Board With Hot Glue
STEP 6: Mount the Laser Pointer and the Alarm Circuit to Form a Single Beam Tripwire
To secure the two pieces in place, you can use tape or a temporary adhesive putty such as Sticky Tack. First mount the alarm circuit in place. Then mount the laser pointer to the opposite side. Carefully adjust the position of the laser pointer so that it is pointed directly at the photoresistor.
Once you have the light from the laser pointer centered on the photoresistor, you are ready to arm the alarm. Flip the switch to connect the buzzer and activate the alarm. Whenever someone walks through the beam, the alarm will go off.
STEP 7: Use Mirrors to Make a Multibeam Tripwire
To accomplish this, you will need a lot of mirrors. There are a number of places where you can get small cheap mirrors. One place is the auto section of your favorite big box store. They often sell plastic sheet mirrors that are designed to replace car mirrors. The major advantage of these is that you can easily cut them to any size and shape that you want. Another good source for mirrors is a craft store. Many craft supplies have a mirror finish. However, the surface is not perfectly uniform. So you won't be able to get as many reflections before the beam starts to disperse.
To set up a multibeam tripwire, start by mounting the laser pointer. Then at the point where the beam hits the opposite wall, mount a mirror. You can use tape or a self adhesive putty. Position the mirror at a slight angle so that it reflects the beam in a different direction. Continue this process adding more mirrors until you are satisfied with the number of beams or the light beam is starting to disperse too much. The last mirror should direct the light to the alarm circuit.
Because this system is using one continuous laser, if any of the beams are interrupted, it will cause the alarm to go off.
STEP 8: Optional: Power the Laser Pointer With the Alarm Circuit's Battery Pack
One terminal of the laser pointer is a spring that sticks out of the internal circuit board. The other terminal of the laser pointer is connected to the inside of the metal barrel. You can easily connect to both of these with a pair of alligator clips. The alligator clips can be connected to the positive and negative lines on the circuit board, or you can connect them directly to the terminals of the battery pack.
By connecting the laser pointer to the larger battery pack you can extend the battery life and you only need to worry about changing one set of batteries.
STEP 9: Optional: Connect Your Laser Tripwire to a Larger Security System
To connect your laser tripwire to another circuit, connect the grounds of both circuits. Then connect the wire that was attached to the negative terminal of the buzzer to the signal input of the second circuit. Set your monitoring circuit to look for a LOW signal. For example, if you are using an Arduino, wire it to a digital input pin and use the digitalRead function monitor the wire. When it detects a LOW signal have it activate the alarms.
394 Comments
mindfreak 10 months ago
Any input or help on this would be greatly appreciated, TIA
gilchristmmxxii 2 years ago
aeroman_123 2 years ago
batvanio 2 years ago
ZaaraB 5 years ago
For a school project, I was wondering if there would be a way to change it so that the alarm sounds at 15hz.
espdp21 2 years ago
DIY Hacks and How Tos 5 years ago
https://www.arduino.cc/reference/en/language/funct...
omarsherifflash 3 years ago
austincheong0824 3 years ago
Bbrinnj 6 years ago
Great alarm, works great. Question, can the buzzer be replaced with an LED or light bulb? Looking for a visual effect.
nighthawk108 4 years ago
ДаниилБ4 5 years ago
According to the datasheet, the NE555 uses an RS trigger built on 2OR-NOT.
1) when applying a beam of light, and then applying power (VCC) inside 555 RS-flip-flop takes the values: R = 0, S = 1, so there is no sound at the out = 1 output.
2) when turning off the light (the voltage drop on R3 increases), i.e. R = 1, S = 1 - the forbidden state for the RS-flip-flop.
How can it work in the forbidden state? Explain, please, but I'm already confused.
Miller7070 5 years ago
Hi!
I've been looking for a
laser switch combination - thank you. Instead of a buzzer being activated what
would you recommend that I use in its place that would act as a trigger/release
switch for a trap/cage door? The trigger/release could possibly be something that would change the polarity on a magnet and would hold open a small
metal door and release the door when the laser beam was interrupted? Any
help is appreciated.
The simplest thing that you can do is replace the buzzer with a low power motor. Or you can use the Arduino setup in step 9 to activate a servo or a solenoid.
haaryavansh 5 years ago
What is the value or R1?
R1 can be anything. But I recommend using a resistance of 1 kohm or higher.
KaiD2 6 years ago
Do you think you (I) could use an IR LED instead of a laser? (They won't let me use a laser at the competition)
DIY Hacks and How Tos 6 years ago
bishaldutta 6 years ago
A laser is used so that light does not spread out over long distance. If IR LED is used then it will spread over a large area and there will be a decrease in accuracy and power at the receiver. You can find some cheap laser diode here: http://s.click.aliexpress.com/e/YznqBQN
