Laser Voice Visualizer
Intro: Laser Voice Visualizer
Like hearing yourself talk? wish you could see yourself talk? shine a laser at a mirror that shakes with your voice.
STEP 1: Parts Layout
(1) ~6" of 1.5" pvc
(2) enough thin plastic to rop around an end of the PVC (typical sandwich bag is fine)
(3) small mirror (find a locket, or use a glass cutter on a mirror, or even use a small piece of polished metal)
(4) laser pointer
(5) tape (duct, I s'pose)
(6) some wood for a base plate
(4) laser pointer
STEP 2: Cover End of Pvc
place plastic over one end of pvc. rap a rubber band tightly over the plastic and the pvc, pull edges of plastic down to tighten the plastic over the pvc hole.
STEP 3: Put Mirror on Plastic
tape the small mirror onto the plastic, as centered as you can comfortably eyeball.
(picture coming)
(picture coming)
STEP 4: Assemble
First tape the pvc tube down, leaving the open end slightly hanging over the edge (you wll be talking / singing into this side). Use a small piece of wood to angle it upwards slightly.
Next, place the laser onto the baseplate. Recommend turning the laser on while attaching it to the base-plate so that you can aim the laser onto the mirror while you tape it down. Another small piece of wood might help angle the laser correctly.
STEP 5: To Use:
Turn on the laser, find where on the wall your laser is pointing. Speak or sing into the pvc and watch as the laser-point on the while vibrates to the sound of your voice. Consider making many for your friends and doing a laser light show.
STEP 6: To Use:
13 Comments
ELF 16 years ago
karossii 16 years ago
Basically, you plug one end with a speaker and the other end has gas intake. They're really fun and as long as you follow typical safety precautions when working with flames and pressurized gas, relatively safe to play around with.
Vissy 13 years ago
ELF 16 years ago
cosmo20346 14 years ago
wethecom 15 years ago
IamTheCreator 16 years ago
FunkNattidelic 16 years ago
connorcancount! 16 years ago
marc92 17 years ago
CameronSS 17 years ago
smartml 17 years ago
mikesty 17 years ago
