Introduction: Lazzer Cuter
To start find a log or image you want to use to cut out and drag it to your desk top then open up partworks
Step 1: Partworks
when you open partworks go to file import then import bite map then edit then trace bitmap
Step 2: Inventor
then export the partworks into a cam file so that you can bring it in to inventor then change the size if you want to then in inventor make drawing bring the logo or drawing in then export in to a dxf
Step 3: Lazzer
then export the drawing as dxf then but the dxf on the flash drive then bring it to the lazzer cutter inzalie then plug the flash drive in bring the and cut
