Learn How to Compost in Less Than an Hour
Intro: Learn How to Compost in Less Than an Hour
Learn how to compost! You don't have to have a green thumb to successfully create a healthy compost bin in your own backyard.
These instructions will help you learn the basics of the composting process. Composting is a cheap, environmentally beneficial way to enrich soil for gardening and landscaping. It helps prevent pollution by reusing organic materials instead of filling up landfills. Composting replaces the need for harmful fertilizers and pesticides, and also prevents erosion. No experience or fancy equipment is needed to start your own compost pile at home. This is not an exact science - just an easy, hassle-free way to benefit your yard. Just follow these simple steps, and within a few months your compost will be ready to add to your garden!
HOW IT WORKS
The composting process is comprised of four main parts: air, water, browns, and greens.
AIR : In order for fast decomposition, the compost pile must have plenty of air. This means that it is essential for the compost materials to be regularly “fluffed” and turned.
WATER : The pile should always be moist, not wet. As one compost-guide describes, the pile should be “moist as a
wrung-out sponge.” If the pile is too dry, the decomposition will be slowed. If the pile is too wet, air is kept from
circulating in the pile and decomposition will slow.
BROWNS : Dry and dead plant material. This includes straw, brown weeds, autumn leaves, wood chips, and sawdust. These materials often need to be moistened before added to the compost.
GREENS : Fresh plant material. This includes green weeds, fruit and vegetable scraps, green leaves, coffee grounds, tea bags, etc.
HOW IT WORKS
STEP 1: List of Materials
Gather the following materials:
-pitchfork or rake
-gloves
-chicken wire (24 in x 10 ft)
-zip ties/cable ties
-gardening soil (1-2 bags of 40 lbs)
-hose/watering can
-compost material (refer to table of "What to Compost")
-4 wooden stakes 3’ - 4’ tall
-mallet hammer
-a friend willing to lend a hand!
What to Compost:
-coffee grounds
-grass clippings
-leaves
-shredded paper (omit non-recyclable)
-tea bags (be sure to remove any staples)
-vegetable and fruit scraps
-wood chips
-cardboard
-yard scraps (old plants, flowers, and small prunings)
-egg shells (be sure they are free from yolk residue)
-hay/straw
What Not to Compost:
-ashes
-charcoal
-dairy products
-food sauces
-invasive weeds
-meat/fish/poultry
-bones
-non-organics (plastic, metal, glass, etc.)
-pet feces
-treated wood
-any material containing preservatives/toxins
-pitchfork or rake
-gloves
-hose/watering can
-mallet hammer
What to Compost:
-coffee grounds
-grass clippings
-leaves
-wood chips
-cardboard
-hay/straw
-ashes
-charcoal
-dairy products
-food sauces
-invasive weeds
-meat/fish/poultry
-bones
-pet feces
-treated wood
STEP 2: Choose a Location
Choose a shady location in your backyard, preferably near a water source (e.g., a faucet).
STEP 3: Constructing the Bin
Fasten chicken wire into a cylinder using plastic ties.
This may require some assistance.
STEP 4: Stake It!
Weave wooden stakes through chicken wire to secure bin to the ground.
STEP 5: Secure Bin
Secure bin by hammering stakes into the ground until bin is stable.
STEP 6: Add Leaves
Add approximately 6 inches of leaves into the bin.
Remember you don't have to make it exact.
STEP 7: Add Soil
Add a layer of soil, enough to cover the leaves.
STEP 8: Water Lightly
Water lightly.
Don't over water. Should be damp as a wrung-out sponge.
STEP 9: Alternate Layers
Alternate adding layers of leaves and soil, until the bin is half-way full.
STEP 10: Add Compost Materials!
Add compost materials to bin.
Refer to list of "What to Compost" and "What Not to Compost."
STEP 11: Mix It Up!
Stir to incorporate compost, leaves, and soil together with pitchfork or rake.
STEP 12: Stir, Water, Repeat
Stir and water lightly a few days a week.
STEP 13: Enjoy Your Compost!
Continue to add compost materials to your bin, and enjoy this eco-friendly alternative to keep your garden growing!
STEP 14: Troubleshooting
Why does my compost smell bad?
This could be caused by compaction.
Solution : Aerate! Stir the mixture more often to create more air movement.
Or, this could be caused by over-watering.
Solution: Add dry leaves or wood chips to soak up water and stir often to promote air flow.
How do I know when my compost pile is ready to be mixed into my garden?
If the pile has:
- shrunk significantly (up to half its original volume) OR
- the original organic materials (the leaves in Step 5) are no longer recognizable OR
- the compost pile is more crumbly than solid
the compost pile is ready. This can take a few months, be patient!
There are flies around my compost bin - how do I get rid of them?
Flies should not be attracted to your compost pile if the food scraps are stirred under the soil and leaves.
Dumping food scraps on top of the pile will attract flies.
Why are there ants in my compost pile?
Ants are a sign that the compost is too dry. Remember to lightly water the compost pile regularly.
If the pile has:
53 Comments
TwoWindsBear 2 months ago
If you're gonna BUY soil to make your compost - why not just BUY the compost????
pfiddle 13 years ago
Par-boil - cool and freeze. Then deep-fry. Great with quiche and a fresh rocket salad.
Alternatively surround the upper wire with clear or at least translucent-plastic (to keep out vertically challenged carrot flies and such) and grow carrots, parsnips or other root-crops. Poke a stick in moist compost fill with good earth mixed with sand and top with young plant. The root-crop will grow straight and look, clean and chop better/easier.
This will also keep your growing season going longer as the rotting compost emits heat and a light translucent 'lid' will keep out frost and one can have crops well into winter. Surround the basket with black(covered) containers filled with (rain/shower)water to keep heat for even longer season.
behrang_a 11 years ago
NaturalCrafter 13 years ago
bahaminb 13 years ago
maji1108 11 years ago
dim20 11 years ago
thecoonskin 11 years ago
RoBear613 11 years ago
if you boiled the meat off the bones, you could probably add them, but it'd probably be a lot easier to pick up some bone meal.
csantiago3 12 years ago
LULUBUG53 12 years ago
I have a very heavy metal cover for it. I am getting compost, however, it needs a lot of churning and turning, and find that adding a few containers of worms does a really good job. If things are large like banana peels, cantaloupe skins,
corn cobs, I cut them down to smaller pieces, either through the food processor, or with the cobs, I let the worms take what they want and bury the rest in the
garden. It seems to decompose over the winter months. Grass and leaves helps also. Thinking of just doing one with grass and leaves this year, to see what
works best. Also think that worms do a great job, so would like to do worm farm.
carman.sharp 12 years ago
vincent7520 13 years ago
I have 2 questions though ::
1) the compost bin seems quite small regarding the time it will rest before being usable. True is is meant to shrink, but as one will also add almost daily some fresh stuff, it may be a lot for such an (apparently) small volume…
2) why some organic materials are excluded from the compost ?
I understand that anything that contains, or may have contained contaminants such as chemical / industrial fertilizers, treated wood, etc… must be discarded. But what about toxins ? They are naturally all over the place !!!…
Then why not ashes / charcoal ? They are used as natural fertilizers in many places : the first fertilization process humanity invented was to burn fields before ploughing them and mixing ashes with earth by the same process…
Same question for dairy products, food sauces (for instance homemade ketchup is only grounded tomatoes and spices) …
It seems quite clear to me that bones should be written off the list as they take so long to decay, but why meat, fish, poultry (unless the reason why is that you don't want to attract animals such as dogs, foxes, forage cats rats, etc…) should be too ?…
Same question for pet feces : animal manure is still the best manure / fertilizer on earth (remember a 3 decades ago the Chinese used human manure to fertilize their fields !…), so why discard them ?…
The last thing that somewhat puzzles me me is is egg yolk residues : are they so toxic that they won't decay properly and / or ruin the whole process ????…
I would be very happy if you could answers us (if you got time and patience, of course… otherwise, no harm done !…).
Cheers !…
Tazo 12 years ago
You want to be friendly to the neighbours all around you.
Fatty acids and proteins will make the compost STINK really really awful.
Throwing oily or greasy food scraps into the compost is the first mistake many people do and they never go back to composting after that happens.
vincent7520 12 years ago
marcintosh 13 years ago
"pet feces : animal manure is still the best manure / fertilizer on earth" Not necessarily, there are things like worms that dogs and cats get and all sorts of pathogens that jump the species barrier. So, no, not "the best stuff on earth"
Egg yolks? Dunno perhaps related to fats and will rot- you'll have to google it sometime.
Here's a linkey-
http://www.compostinfo.com/tutorial/CanICompostIt.htm
Marcintosh
If you can burn the bones (in a wood-burner) and use the ash on your veggies - potash it's called. Don't use coal-ash on vegetables - all sorts of heavy metals (quiet kind) in it - but again fine for shrubs and trees - in small amounts - you don't want your garden to be a toxic dump - and always remember what you put in the flowers this year gets on the veggies next year. Shrubs and trees usually last a few years - at least.
But keep posting : that makes me learn more.
To all of those who read this post : have a nice week-end !.
Spring is here, at least in the northern hemisphere, and I hope you all have happy moments ! …
cheftpm 13 years ago
