Introduction: Leather SD Card Holder / Nintendo Switch Card Holder
Take with you only what you need! An elegant, eye-catching and perfekt solution to store your SD cards and Nintendo Switch cards. Fits perfect in the pocket, smells good and fills great in the hands. Okay, let us make one :)
Step 1: Materials and Tools
Materials
  • Leather of your choice (3 - 4 oz / 1.2 - 1.6 mm is my recommendation)
Tools
  • Cutter
  • Cutting mat
  • Scissors
  • Ruler
  • Hammer
  • Half round punches
  • Scratch awl
  • Wood slicker
  • Stitching chisel (5 mm is my choice)
  • Leather glue
  • Wing divider
  • 2x needles
  • Sew thread (0.55 mm is my choice)
  • Beeswax block
  • Tokonole leather finish colorless (optional)
  • Sandpaper
  • Edge beveler
  • Lighter
Step 2: Print, Cut and Tracing Out the Pattern
Download free attached pattern, print and cut them out. Transfer the pattern on each leather piece. Use the scratch awl tool. Use the ruler, cutter and half round punches to cut the leather pieces out.
For inner round edges use half round punches.
Use the following printer setting:
Paper size European: DIN A4
Paper size USA: US Letter
Step 3: Glue the Leather Pieces Together
Glue the card pockets with the main part together.
Optional: You can sand and burnish the round inner edges. Use tokonole leather finish and the wood slicker to burnishing them.
Tipp: To remove the excess glue use a plastic card or metal ruler.
Step 4: Punching Holes and Sewing
  1. At first punch holes on the middle stiching marks of the card pockets and sew them on the main part. For sewing i use the saddle stitch technique WITHOUT a stitching pony. HERE you can learn from "Corter Leather" how to do that.
  2. Sand the outer sides.
  3. Adjust 0.3 mm on the wing divider and mark the stiching lines (You are new on leather craft? Just search on YouTube for "How to use wing divider").
  4. Punch the holes and sew the rest together. Finally snip and burn the sewing thread ends.
Step 5: Finishing the Edges
  1. Cut a little bit leather off on the corners.
  3. Use the edge beveler for taking off the sharp edges.
  4. Burnish the edges. Use tokonole leather finish and the wood slicker to burnishing the edges. You can use water as well. You can find HERE a very useful tutorial from "Corter Leather".
Step 6: The Finished Product
We are done! I would be glad to see your leather sd card holdes / nintendo switch card holders :)
*** My Links ***
Instagram: https://www.instagram.com/paracord.wolf/
Etsy: https://www.etsy.com/de/shop/LionAndCrossLeather
