Leather Wristband/cuff for a Watch
Intro: Leather Wristband/cuff for a Watch
Learn some leathermaking while crafting a custom 22mm watchband/cuff. This was originally created for the Pebble Smartwatch.
Materials Needed
- Scissors
- Exacto Knife
- Printout of template
- Needle & waxed thread*
- Leather scraps
- Watch clasp
- Sewing Awl
- Beeswax
- Optional: Edge Beveler/Groover
*You can either purchase waxed thread, or easily make your own by melting some of the beeswax and dunking a length of doubled thread.
Created for Making and Maker Spaces class through St. Catherine University.
STEP 1: Working With the Pattern
- Cut out the paper pattern.
- Test on your wrist with your watch face. It is scaled up for a guy, so you may need to trim the length for smaller wrists/different sized watch face.
- Use scissors or an Exacto knife to cut out leather.
- Use your sewing awl to poke holes to mark where you will be sewing.
STEP 2: Prepare the Leather Pieces
- Round the edges by using your edge beveler on the front and back of your leather. If you do not have an edge beveler, use scissors to trim the front and back at an angle.
STEP 3: Sew It Together
To sew, you will probably need to re-poke holes with sewing awl through both halves as you go along.
Clasp piece
Fold the end with the two flaps around your clasp. Sew one stitch on each flap. Fold the band so that the end of the band will meet the ends of the flaps. If you want a stiffer band, cut out thin cardboard to insert in the middle. Stitch along the places you marked, leaving a small space for a watch spring bar at the top.
Holes piece
Fold in half. Leaving a space again for the spring bar, sew in the marked spaces. When finished, make holes for the clasp with your sewing awl. (note this is much easier with a leather hole punch thing).
Strap Keeper
Optional: Stiffen leather by soaking for 10 minutes in cold water, then for a few minutes in hot water (not boiling). This will shrink the leather so you will need to make it larger than shown on the pattern
Place two stitches to join the circle together.
STEP 4: Finish Edges
- Dip the edges of the leather pieces in melted beeswax.
- Run the edges in a groove about the same width as the edge. I just carved out a little bit of my handle to make a groove. Do this until the edges look darker and smoother.
- If you have visible beeswax on the strap edges or stitches, use a hair dryer to slightly melt the wax and wipe off with a paper towel.
STEP 5: Assemble and Wear It!
Put all your pieces together and you're done!
3 Comments
swim11 8 years ago
pucksurfer 8 years ago
Cool
DIY Hacks and How Tos 8 years ago
This looks great.
