Led Clock
Intro: Led Clock
Hello everyone....
This clock uses
150 Red 5mm Led (2 V/10mA)
61 Green 5mm Led(3.4V/20mA)
and a clock machine.
This clock uses
STEP 1: Unregulated Capacitive Power Supply
For Red Led
We Use :-
1. 105K/400V Metallized Polyster Capacitor
2. 47E/2Watt Bleeder Resistance
3. 1N4007
4. 220 E/1Watt Resistance
5. 10uf/450Volt Electrolytic Cap
6. 1 M / 1/4 Watt Resistance
For Green Led
We Use:-
1. 474K/400V
2. 10E/1 Watt Bleeder
3. 1N4007
4. 220E/1Watt Resistance
5. 10uf/250 Volt Electrolytic Cap
6. 1 M/ 1/4 Watt Resistance
We Use :-
3. 1N4007
For Green Led
We Use:-
1. 474K/400V
3. 1N4007
STEP 2: Circuit Diagram
The circuit is quite simple as it is the most common transformerless power supply.
The calculation for measuring current through Capacitor is given in the diagram itself.
Now we are calculating the power consumption by applying simple formula i.e. P= V x I
"The readings was taken when circuit is connected to A.C mains.
So be very careful about not to short circuit with multimeter wire pins."
The total potential difference across series of Red Led comes about 286 Volts with average current of 7 mA.
Power = 286 V x .007 A
= 2.002 Watt
and for Green Led same procedure applies,
Power = 182 V x 14.5 mA
= 182 V x 0.0145 A
= 2.639 Watt
Power loss through resistors is assumed to be less than 1 Watt.
So,
Total power Consumption= 2.002+2.639+ loss in Resistors
= 4.641 + 1 watt maximum
= 5.641 Watt
= 2.002 Watt
= 182 V x 0.0145 A
= 2.639 Watt
So,
= 5.641 Watt
STEP 3: Board Dimensions
Square Card board has been used of side = 12 inch or 1 feet.
The radius of Clock Circle is around 12.5 Centimetre. Just arrange the led in a format of clock and you are done.
Thanks for Reading.
Thanks for Reading.
7 Comments
chrisjlionel 8 years ago
Hemant Jain 8 years ago
marcoboers 9 years ago
Hemant Jain 9 years ago
1. The parallel array takes more current from source since current gets divide ,so we have to choose higher value of metallized polyster capacitor.
2. The value of Output Cap needs to be changed to higher since more current would filters out.
3. Comparatively Complex and Bulky Wiring which takes more time and resources.
4. Cost and Size of Circuit also becomes high.
At last the only advatange with being in parallel network is safer voltage level can be easily acquired which do not gives shock.
Also note that Only Voltage is high in this circuit , Current is in milli Ampere (around 35 to 60mA).So it is not so dangerous as it seems to be.
Thanks.
