Introduction: Led Cube 4x4x4 With Max 7219
First excuse my english :)
Hello, I wanted to make a 4x4x4 cube, but I know nothing exadécimal
So I took a arduino uno and a max 7219
Amazing 3 dimensional LED display.
64 LEDs makes up this 4 x 4 x 4 cube, controlled by an arduino and max 7219
Each LED can be addressed individually in software, enabling it to display amazing 3d animations!
Step 1: What You Need
Step 2: Instruction 1
As you can see, I have separated the LED module into 4 equal party and I visualized them one above the other. like this A, B, C, D.
and will connect the (row and col) pin on the MAX 7219
Step 3: Instruction 2
1. each hole for LED is spaced 1 inch center hole.
2. as you can see, the brass wire is soft, ready inserted between two clips, stretched to sharply.
3. folded all anode.
4. sorry I forgot to take pictures during the welding step
but if you watched on another picture, you'll understand
Step 4: Instruction 3
all, the connector are on the outside.
Step 5: The Code
all the (void), are in the individual part
at the end of the program, there is a void like this
void loop()
{ allume(); ferme(); ligne(); plateau(); aleatoir2(); mur(); cube(); plateau2(); vague1(); ligneverti(); cube2(); axe(); aleatoir(); elice(); roue(); vague2(); vague3(); diago(); tunel(); serpent(); }
Step 6: Finishing Up
Hope this helps someone!
I had a sleepless night
It took me a while to understand how to do this,
Feel free to comment Thank you, Merci
