Led Cube 4x4x4 With Max 7219
Intro: Led Cube 4x4x4 With Max 7219
First excuse my english :)
Hello, I wanted to make a 4x4x4 cube, but I know nothing exadécimal
So I took a arduino uno and a max 7219
Amazing 3 dimensional LED display.
64 LEDs makes up this 4 x 4 x 4 cube, controlled by an arduino and max 7219
Each LED can be addressed individually in software, enabling it to display amazing 3d animations!
STEP 1: What You Need
STEP 2: Instruction 1
As you can see, I have separated the LED module into 4 equal party and I visualized them one above the other. like this A, B, C, D.
and will connect the (row and col) pin on the MAX 7219
STEP 3: Instruction 2
1. each hole for LED is spaced 1 inch center hole.
2. as you can see, the brass wire is soft, ready inserted between two clips, stretched to sharply.
3. folded all anode.
4. sorry I forgot to take pictures during the welding step
but if you watched on another picture, you'll understand
STEP 4: Instruction 3
all, the connector are on the outside.
STEP 5: The Code
all the (void), are in the individual part
at the end of the program, there is a void like this
void loop()
{ allume(); ferme(); ligne(); plateau(); aleatoir2(); mur(); cube(); plateau2(); vague1(); ligneverti(); cube2(); axe(); aleatoir(); elice(); roue(); vague2(); vague3(); diago(); tunel(); serpent(); }
STEP 6: Finishing Up
Hope this helps someone!
I had a sleepless night
It took me a while to understand how to do this,
Feel free to comment Thank you, Merci
10 Comments
AbdullahA62 7 years ago
if I want to make 8*8*8 from the the same circuit... what should I do?
toastdore 7 years ago
Hello, the base is plexiglass 3/16
SelvaK3 8 years ago
what type of material did you use for base because i made the led cube but dont know what should i do with the base to support my cube.
TiborS16 8 years ago
I can't see what size LEDS you have used, or the
type does it make a difference?
toastdore 8 years ago
the LED is 5mm
http://www.cafr.ebay.ca/itm/50pcs-5mm-Water-Clear-...
jollifactory 8 years ago
Nice work with the MAX7219 IC driven 4x4x4 LED Cube. Not too long ago, we designed an 8x8x8 LED Cube also using the MAX7219 ICs. If you are interested, you may find it at
https://www.instructables.com/id/JolliCube-an-8x8x8...
Thank you, I saw your cub 8x8x8, it's great
for the video
A_S_H 8 years ago
