Introduction: Lego Mindstorm Turret Shooter
In this Instructable I am going to show you to the best of my ability how to make a Lego Mindstorm Turret Shooter I am mainly going to use just pictures because thats how lego does it. All the parts you need for this instructable are in the Mindstorm 2.0 NXT kit.
Step 1: Parts From the Kit Needed
These are the parts you need from the NXT kit.
Step 2: Base Part 1/3
This is the first part of the base you need to build
Step 3: Base Part 2/3
this is the next part of the base you need to build
Step 4: Base Part 3/3
Now we make the final part of the base and put the 3 parts together
Step 5: Putting the Base Together
Now we put the three parts of the base together to make it complete
Step 6: 360 Turning Piece
Now were going to make the next piece i don't really know what to call it so look at the first picture
Step 7: The Shooting Mechanism Part 1/6
this is just one of the sides of the supports that holds up the motor that shoots the plastic balls.
Step 8: The Shooting Mechanism Part 2/6
Next were going to make this which is basically a mirror image of the pervious piece we built.
Step 9: The Shooting Mechanism Part 3/6
Next were going to make the piece that points the shooter up and down so follow the pictures
Step 10: The Shooting Mechanism 4/6
next were going to make this which is part of the firing system.
Step 11: The Shooting Mechanism Part 5/6
this is one of the last pieces we need to build it is what holds the plastic balls before they are fired
Step 12: The Shooting Mechanism Part 6/6
This is hardly a step because it's just putting two connectors in a motor but here it is anyway
Step 13: Putting It All Together
Step 14: Oops
I forgot when I was building this that I ordered extra connectors and used 2 extra black connectors then what comes in the standard 2.0 NXT kit you can easily substitute a black connector for a long blue connector or short grey connector in many places.
Step 15: Controlling It
Right Now I just use the remote control through bluetooth function on the NXT software. with port A as the Action and BC as keypad controlled
