Lego Power Functions Vehicle (With Video)
Intro: Lego Power Functions Vehicle (With Video)
This is the second remote control Lego Power Functions vehicle that I have uploaded to Instructables. If you have not seen my first one(a tank), here is the link. Since this one uses large rubber tires instead of tracks, it is a lot faster and maneuverable.
These are the Power Functions Items that you will need to build this project. If you are missing some of the items, you can buy them off of LegoShop.com.
- (2) Small Motors
- (1) Battery Box
- (1) IR Remote Control
- (1) IR Receiver
There are several sets that the large rubber tires come in. If you don't have them, I'm sure you can substitute them for smaller ones. The rest of the pieces can be found in most standard Lego Technic sets.
This project will probably take about 15-30 minutes to make depending on how fast you can find your pieces in your collection of Legos.
- (2) Small Motors
- (1) Battery Box
- (1) IR Receiver
STEP 1: The Battery Pack
Here, we will get the battery pack ready for the rest of the model.
Pictures:
1) Get out you battery pack. Note the orientation of the battery pack in the picture. This will be IMPORTANT later on.
2) Find four Hassenpins
3) Stick two of them onto the battery pack as shown.
4) Same for the other side.
Pictures:
STEP 2: Building the Mainframe
In this step we will build the mainframe.
Pictures:
1) Insert two long black pins into a three length beam as shown.
2) Put one of the long black pins into the second hole of a 15 length beam.
3) Do the same with another beam.
4) Build another one.
5) Attach one of the structures to the battery pack as shown.
6) Do the the same with the other side. Be sure that you are sticking the Hassenpins through the correct holes on the beams.
Pictures:
STEP 3: Completing the Mainframe
Pictures:
1) Insert two long black pins into a right angle Hassenpin.
2) Put a three length beam on the two pins as shown.
3) Put another right angle Hassenpin on top.
5) Attach the two structures to the model as shown.
6) Put two 15 length beams on the Hassenpins.
STEP 4: Adding the Motors and Tires
This is the fun step where we get to add motors and tires.
Pictures:
1) Start here.
2) Snap the motors onto the black pegs.
3) Get a 7 length rod,...
4) ...insert it all the way into the motor, and add a bushing.
5) Do the same for the other motor.
6) Add LARGE rubber tires onto the rods.
Pictures:
1) Start here.
STEP 5: Front Wheel
There are ten pictures to this step so make sure to arrow over to see all of them.
Pictures:
For this one I wont narrate step by step; just build what is in the pictures.
Pictures:
STEP 6: Attaching the Front Wheel
Pictures:
1) Put two, three length rods into the piece shown.
2) Put the piece onto the model as shown.
3&4) Do what is shown.
5) Attach the front wheel
STEP 7: Receiver Support Structure
Pictures:
1) Add a 9 length beam.
2,3,&4) Hold it in place using black pins.
STEP 8: Mounting the Receiver
Pictures:
1) Add a Hassenpin.
2) Add another Hassenpin.
3) Add a three length beam.
4) Add the receiver.
1) Add a Hassenpin.
STEP 9: FINAL Step- Wiring
Pictures:
1) Connect the receiver to the battery pack.
2&3) Connect the motors to the receiver.
4&5) You can use two, three length beams connected by two black pins to pin the wires back neatly.
STEP 10: Troubleshooting
The remote doesn't work.
Make sure that the battery pack is on and that the remote and the receiver are on the same channel.
The switches on the remote aren't controlling the right motors.
Switch which motor is connected to what terminal on the receiver.
The wheels are going the wrong way.
Fix this problem using the toggle switches on the remote.
I will answer any more questions that you post as comments. I am entering this into the Toy Challenge 2 so if you like it, please vote. Thanks!
5 Comments
YiZ 8 years ago
the computer no1 9 years ago
SwaggerFul Swellow 10 years ago
monsterlego 12 years ago
keep up the good work!
Troy_1 12 years ago
