Lego Rocket Launcher
Introduction: Lego Rocket Launcher
This Lego rocket launcher will blast away all of you enemies! Make sure to share this if you made it. This Lego weapon is a short range rocket launcher. I will be posting every once and a while so stay tuned!
here is what you will need:
4 2x2 bricks (one should be a different Color from the other three) colors may vary 1 brick 2x2 with pin and cross hole 1 5M beam 2 cylinder pieces 1 cone piece 1 2x6 brick
Step 1: Step 1: the Grip
Grab your three 2x2 bricks of the same Color! You will need them! This is a very simple step. Just stack these three on top of each other and then...
BOOM!!!!!! You finished the first step!
Step 2: Step 2: the Barrel
On this step you need to go search for a 2x6 brick. Put this on leaving one stud hanging out in the back like the picture shows. And then you are done with step 2.
Step 3: Step Three: the Holder of the Launcher.
wow! You made this far. Now we need to add a single 2x2 brick to the back. (You will need a different Color for this part) attach this brick to the one stud of the barrel we left and then you have the holder of the brick put in place. Congrats!
Step 4: Step 4: the Axle
this is what powers the launcher to throw the rockets! Just like the last step put this on the 1 stud that is sticking out like the picture shows. If you hold it like a gun, make sure the part that is sticking out that holds the launcher is to the left.
Step 5: Step 5: the Real Stuff
now you will need to put on that launcher on to the axle like the picture shows and.....
KA-POW you just finished the launcher
Step 6: Step Six: the Rocket
now for the fun stuff. Use your cylinders to make it look like this. It is optional to put a cone on top.
Step 7: BOOM
now you may be wondering how to use this. Lucky you I’m going to teach you. Put your thumb like the picture shows then flick it with your free hand.
Now to start ww3!
Be the First to Share
    • Raspberry Pi Contest
    • Jewelry Challenge
      Jewelry Challenge
    • Photography Challenge
