Introduction: Lego USB Drive
I created my own Lego USB Drive, I used the instructions that ianhampton did, here is a link to it. Here is what I did to make it.
Other tutorials used silicon to fill the inside, I used a 2 part epoxy. I just got the wrong thing but it works just as well and it is SOLID.
COMING SOON
I'm going to be making a cap for it. Its becoming a pain because trying to line it up and fill it so it can go on.
Step 1: List of Parts & Tools
Parts List
- Cruzer mini USB Flash Drives
- 1 x 1 Tile
- 1 x 8 Plate
- 2 x 8 Plate
- 1 x 6 Brick
- 2 x 3 Brick
- 2 x 6 Brick
Tools (Not Shown)
- Exacto Knife
- Needle Nose Pliers
- Krazy Glue Pen
- Quick Set 2 part Epoxy
- Disposable cup or container to mix epoxy
- Rubber Surgical Gloves
- Rubbing Alcohol
- Rag
Step 2: Cutting the Bricks
Using the exacto knife I cut all the bricks. I also used the needle nose pliers to remove some of the bigger pieces and then cleaned up the rest with the knife.
Step 3: Pre Glue Prep
Other tutorials say thay had to use a steady hand while the glue set. I use some 1 x 1 round bricks and a 1 x 4 brick with a 6 x 12 plate to hold it while the glue set. I used the round 1 x 1 bricks to lessen the chances that the glue would get on the bricks. It only happened to one of them.
Step 4: Gluing the Bricks Together
Using the crazy glue pen put glue on each piece and put it on the plate. I used the circles under the plate to hold the parts better.
I know Crazy glue sets and hardens quickly, but I sell let it sit over night.
Step 5: Cutting the Opening for the USB Drive Connector
Most other tutorials show just cutting from the bottom, I was not about to do that. This was the hardest part to get it lined up correctly. I just carefully kept lining up the connector and using the knife to scribe a line to go by. Mine is not perfect but I think it came out good. I had to keep cutting and scraping to get the connector through the slot.
Step 6: Assembly
I took a 1 x 1 tile and glued it in side to act as a support to hold the USB drive at the correct height.
YOU WILL NEED RUBBER GLOVES FOR THIS STEP
Next Insert the USB Drive in and position it and fill with epoxy, do not over fill. Sorry there are no pictures for this. I had to be quick with the epoxy. Do not over fill, and after you have enough epoxy put the 1 x 8 and 2 x 8 pieces on the back and CAREFULLY and I can not stress this enough, be careful, it will get very warm, as the epoxy sets. You will need to hold it for about 10 minutes. I built a jig out of other Lego's to hold it.
As the epoxy sets you might get some run off, this is where you might want to have some Rubbing Alcohol and a rag to wipe up excess run off that might seep out of the side.
Step 7: Completed Lego USB Drive
Here are the images of the Lego USB drive. not 100% perfect, but I'm happy with it.
67 Discussions
10 years ago on Step 2
how hard is it to cut the legos?
10 years ago on Introduction
Thanks for the idea! my dads had a usk full with maskintape... this really looks better!
11 years ago on Introduction
I made one in a 2x4 block (: Also with a cap. Only difference i think, is that i closed it in the bottom, so it wouldn't be so big (:
Reply 11 years ago on Introduction
Mine is closed on the bottom as well .. if you see the 2nd pic of step 7
I wish i could make the image stuff work....
Mine is only a 4x2 block, not even a 1/3 height block underneath, but still closed so i can build it into things.
And sorry i didn't see your reply before now (:
11 years ago on Step 7
Whoa! I can't believe how easy this was! And it looks cool too!
Reply 11 years ago on Step 7
Then post a pic ... lets see your work!!!! I hope my Instructable helped
12 years ago on Introduction
Cool VId, Portable apps RULE. I have a 1 gig flash drive (Non-Lego) and I have a bunch of portable apps on there. You can learn more at PortableApps.com. That site and other sites. Very helpful. I use it on my work laptop all the time. and Portable KeepPass is one of my favs. I have it on my flash drive, Desktop and My phone.
Agreed portable apps rules
Its on my ipod
what kind of table did u use when you took the pictures
don't recall ...but that is a piece of paper it is on
Wait arent there 2 of these posts?
Your not the first one to say that, but mine is different then the others, any way there many versions of many things on this site, this is just my interpretation
Ok
13 years ago on Introduction
how do you open this kind
Sledge Hammer?
Cutting, I used to have the one. You need a very sharp knife and something to hold it with so you don't chop your arm off.
Reply 12 years ago on Introduction
with a hammer lol, but seriously i think its held in by clips so try using a knife carefully
It is either Ultrasonic welding or it is heat sealed
