Let's Make Some Pineapple Beer!
Intro: Let's Make Some Pineapple Beer!
I've been making pineapple beer from a young age. Whenever I managed to salvage some pineapple peels before it went to the compost heap, I would drop it in a bowl with some water and sugar and let it stand. A few days later I had some sweet, pineapple flavoured water with a few bubbles. Delicious.
Forward a few years and things got a bit more precise. I started to experiment with quantities and different flavours to get the recipe just right — not only flavour and taste wise, but also to get a bit of buzz from the brew.
In the past I've used an enamel bucket my mother bought years ago for brewing ginger beer. It has a lid with a dome for ventilation and I got about 6 liters of brew from it. But for this Instructable I'm going to upscale everything and go for around 25 liters.
So let's begin...
STEP 1: What We Need
Ingredients
4 Pineapples (about 600g each). Make sure they are nice and ripe. Remove the crown and any loose leaves, but do not peel!
1 cup of sugar per liter of water, about 22 cups or 4kg
22 liters of very hot water
2 x 20g packets of granulated yeast (Brewer's yeast)
Equipment
25 liter container/fermentation tank
Blender (sort of optional)
Measuring cup and funnel
Cutting board and knife
Enough 2 liter plastic softdrink bottles to bottle your brew. I never fill my bottles to the top, so keep that in mind. (I do not recommend glass bottles. They can explode.)
Hydrometer (optional)
STEP 2: Before We Start...
Clean everything.
Use hot water and soap and clean everything. Your work area, your cutting board, knife and especially your fermentation tank, blender and bottles. Make sure no soap remains in the tank and bottles. Wash the pineapples under running water too.
We do not want unnecessary things to grow in our brew that can alter the flavour or even destroy the brew.
All set? Let's go!
STEP 3: Prepare the Pineapple Base
Note: using a blender is optional. I like to get as much flavour and juice out of the fruit. If you do not have access to a blender, just finely chop up the pineapple and collect as much juice from the cutting board.
Chop up a pineapple and put the pieces in the blender. Add 500ml boiling water and, starting with the Pulse function, blend into a smoothie. Pour into the fermentation tank. Repeat the process until all the pineapples are pulped and in the container. Now boil another liter of water and "wash" the blender to get every last bit of pineapple into your tank.
By now we have used 3 liters of water (4 x 500ml + 1 liter). That means we need to add 3 cups of sugar to the tank (since we use 1 cup of sugar per liter of water).
STEP 4: Filling the Tank
Now we can start adding the sugar and water. I start by adding 10 cups of sugar to the tank, followed by 10 liters of very hot water. *The water from your hot water tap is fine (if you can drink your tap water of course). The reason we use very hot water is that all chlorine has been evaporated (chlorine can kill the yeast). It also helps the sugar to dissolve.
Continue adding water and sugar until you reach the desired level in your tank. Do not overfill, when the brew starts to ferment, the gasses need to go somewhere.
Before we can add the yeast, the mixture needs to cool down.
* EDIT 2016/07/25: Online forums are divided whether you can use hot water from a tap or whether you should boil the water. I asked a homebrewer I know and he says boil. I've never had any problems with very hot tap water. So... up to you.
STEP 5: Adding the Yeast
When the temperature of the mixture reaches about 25-26°C you can add the yeast. If the mixture is too hot it can kill the yeast, too cold and it will not activate.
Put the cap loosely back on the tank. Do not tighten it — the gasses need to escape somewhere. An alternative is to put a clean dishcloth over the opening and keep it in place with a rubber band.
Optional: if you are using a hydrometer you need to take an Original Gravity reading after cooldown but before adding the yeast. (For interest sake, my brew's OG was 1.040.)
STEP 6: Ferment
Find a nice warm space for your fermentation tank. Leave it there for at least 7 days.
STEP 7: Bottling
After 7 days your brew should be ready for bottling. Take a bucket or any other container and cover it with a cheese cloth or clean dishcloth. I discovered something called mutton cloth and it works really well. Securely fasten the cloth with string. Put the bucket under your fermentation tank and drain your brew through the cloth.
If the bucket becomes full, transfer the liquid to the plastic bottles using a funnel. I use 2 liter bottles and fill it to where the neck part starts. After bottling, fermentation continues. If you want to vent the bottles from time to time or open a bottle to drink, this space will allow you some time to control the venting. Otherwise the brew will just explode out like a geyser.
After bottling, screw on the caps tightly. I leave the bottles outside for another few days to continue fermenting and only put it in the fridge before drinking.
STEP 8: Enjoy!
Enjoy!
STEP 9: One Last Note...
I'm adding an air lock (for venting) and a temperature strip to my fermentation tank. I've ordered it, but it has not arrived in time.
Since you've read this far, here's a bonus: you can use this recipe for ginger and apple beer as well. Substitute the pineapples for 750g fresh ginger or 2,5kg red apples (I haven't tried green apples yet). When making ginger beer, add 2 or 3 chillies to the mix. Well worth it.
I'm waiting for the mango season, because I really want to try mango beer...
314 Comments
JacoG1 7 years ago
dylanvanderwalt75 4 years ago
Thank you so much for the receipt .
If i left my fermentation only for 4 days and then drink the beer will it work ?
JacoG1 4 years ago
geraldinecb78 4 years ago
JacoG1 7 years ago
Update #3. I won a runner-up prize in the Homebrew 2016 competition with this Instructable! Thanks for all the views, the comments and everybody who voted!
JacoG1 7 years ago
Hi everyone, quick update #2. Yesterday was (a very messy) bottling day. I updated the relevant step with photos. The spigot eventually clogged up, but I got a siphon just in case. Everything look and taste really good.
Craig9110878 3 years ago
It had more of a 'mimosa' texture. Juice mixed with champagne.
Otherwise really really loved it. Punchy, fruity, sweet with a nice kick! ❤ 🥰
LEONPUTTER 1 year ago
andre.g2mail 3 years ago
Blend the ingredients in cold water, (because the warm water expands the air in the sealed blender. Thats a disaster waiting to happen)
Once its blended then put it in a pot and bring it to boil for 2 minutes. the boiling kills the natural yeast and bacteria. Once boiled throw it into your
sanitized fermenting bucket and bring the wart down to 24 degrees celcius before pitching your yeast. I use ice to speed the process Now you have a sanitised batch of pineapple beer in the making. No headaches, good, clean and safe drinking.
Tonyoca 3 years ago
I made the ginger beer and the Pineapple cider. Both gave me an instant headache after 1 glass. What am I doing wrong. Help 🙈
JacoG1 3 years ago
Tonyoca 3 years ago
My Cider has been fermenting for 7 days now. Can I leave it for longer. Or is it better to strain it and decant it now and let it continue fermenting in smaller bottles. Thanks.
JacoG1 3 years ago
Tonyoca 3 years ago
Lee-Anne10 3 years ago
irenewhite855 4 years ago
JacoG1 4 years ago
