Levitating Key-holder Shelf
Intro: Levitating Key-holder Shelf
You've surely seen some of those videos on youtube about levitating stuff.
In this Instructable, i will share with you the process of making a levitating key-holder shelf. It wasn't an easy build, since i am not good in electronics, but after some research it was done.
With the electromagnets in this settings you can levitate up to 34 Gr.
I hope every one will finde this useful.
( I will upload Pdf's, for the different cuts in this project, in a couple of days )
STEP 1: What You Will Need :
For making the box :
- some wood, i used a thickness of 3 mm.
For the Electromagnets :
- 5Volt-Regulator 78L05 x 3 ( 0,2 USD x 3 )
- hall sensor SS495 x 3 ( 4 USD x 3 )
- op-amp UA741 or LM348 x 3 ( 5 USD x 3 )
- P-channel MOSFET IRF4905 x 3 ( 1,25 USD x 3 )
- capacitor 10 uf x 3 + 100 n x 6 ( 4 USD x 9 )
- resistor 10 k + 100 k x 3 ( 0,1 USD x 6 )
- an electromagnet 15 mH, 2.4 Ω1.5 A maximum1.5'' diameter x 1.0'' length x 3 ( 14 USD x 3 )
- N52 neodymium disc magnet1/2'' diameter x 1/4'' thickness, 6 gNi coated x 3 ( 4 USD x 3 )
- a board for soldering components
TOTAL PRICE : 108, 2 USD
Otherwise you can buy a kit, a good place is from http://zeltom.com/products
a price for : 48 USD for a kit
STEP 2: Building the Box
I used a laser cutter from my friends school to cut the pieces, it is straightforward, i will attach the drawings here. otherwise just follow the steps.
The rings are made to hold the electromagnets in place.
STEP 3: The Electromagnets - Some Theory
The electromagnetic levitation controls the magnetic field generated by an electromagnet to levitate a small magnet in midair. The small magnet levitates in the air indefinitely without any disturbance.
The physics behind it is to simply provide a magnetic force which equal and opposite to the gravitational force on the object. The two forces cancel and the object remains suspended. Practically this is done by a circuit which reduces electromagnet force when an object gets to close, and increases it when the object is out of range.The vertical position of the levitating magnet is measured using a linear Hall effect sensor and the current in the electromagnet is controlled using a digital signal controller.
STEP 4: Building the Electromagnets
Since i am not good in electronics, I bought a kit from http://zeltom.com/products, . So i cannot share the schematics here. So i wont go in details here, since if you choose to buy the kit it is self explanatory.
But there is a lot of tutorials out there on how you can build your own levitation device, one of the best websites is this one : http://www.bis0uhr.de/projekte/schwebekugel/englis...
( the items of my component list are compatible with this schematics )
When the electromagnets are built, put them inside the box, inside the wooden rings, so they can be hold in place.
STEP 5: Building the Magnetsholder for the Key Ring
I will attach my pdf for the cuts. it is self explanatory. the aim is to build some wooden holders for the key rings,
STEP 6: Bringing Every Thing Together.
Fill the box with electromagnets, and attach it to the wall, plug the power adaptor ( 12 v, 4 A ).
STEP 7: The Final Step.
Enjoy
22 Comments
armandsskutans 6 years ago
ede waard 8 years ago
The_Spaniard 6 years ago
It's a Volkswagen key.
stevempotter 8 years ago
Nice! How to scale up for heavier loads?
Is erasing credit cards in your pocket a problem with the magnet on the keychain?
mscott41 8 years ago
stregoi 8 years ago
exactly !
andrea biffi 8 years ago
great project!
stregoi 8 years ago
thanks
Team Z 8 years ago
Amazing project! Very very cool. Thanks a lot for sharing it with us!
stregoi 8 years ago
thank you
mick__326 8 years ago
Looks great and easy to make it... cheers
stregoi 8 years ago
thanks
velikara 8 years ago
It looks very nice
stregoi 8 years ago
thanks
Raspberryhacker 8 years ago
stregoi 8 years ago
hehe .. yeah right
GeorgeO13 8 years ago
Just what that fantastic!
DIY Hacks and How Tos 8 years ago
This looks amazing!
pstaples2 8 years ago
Jiajiun 8 years ago
I think the pull of the magnet is not a fixed value, it is dependence on the weight of the keys. but how it works? I think it is the function of "Hallsensor".
