Light-Up Guitar Strap
Intro: Light-Up Guitar Strap
Hello! In this Instructables I'll outline how to make your own sound-reactive guitar strap using addressable LEDs along with a Circuit Playground Express board.
STEP 1: Attach Holder and LEDs
Slide the battery and CPE board into place as shown, then hot glue the assembly to the end of the strap.
LED strips will typically have adhesive on one side, but poke some holes as shown and use zip ties to really fasten it down. Sewing would also likely work.
STEP 2: Code
Install circuitpython code from this repository. You'll want to modify the NUM_PIXELS_EXTRA value to correspond to the number of LEDs on your strip (or PCBs as outlined below). Adafruit has lots of info on using and coding these devices here.
STEP 3: Connect LED Outputs
Connect Vout and GND to the corresponding addressable LED pins. The control signal is via A0 per the way it is coded, but that could be modified. Note that the signal only goes one way.
Here Dupont connectors with alligator clips are used for an easy solderless connection, but soldering would be even better.
STEP 4: PCB Version
While using an LED strip is fairly easy, if you happen to have extra PCBs with addressable LEDs onboard lying around, or want to purchase a few, you can do largely the same thing with them. Check out the video to see the process.
STEP 5: Rock Out!
Enjoy entertaining crowds with your new lighting device. Please let me know if you build one!
