Light Seeking Robot ATLAS_15
Intro: Light Seeking Robot ATLAS_15
Hey guys this is my first instructable,in wich i'll teach you how to make a light seeking robot.This is a project i've made ,because i like robotics, and i'm starting with it, so it's a simple way to build a robot.I've made it with very cheap materials, but if you want you can make it better ,i'm planning to make a radiocontrolled one , but i dont know anything about it .
Let's get started !!!....
STEP 1: Part List and Materials
For this instructable you'll need :
2 Plastic circles , i used circles but you can use any shape
3 big screws and bolts
Hot glue and hot glue gun
Cables (1,5 meters aprox.)
2 Dvd 5.9 Volts Motors
2 TIP120 Transistor
2 1k Resistors
2 1N4001 Diodes
2 LDRs
1 breadboard (optional , i didn't use it ,but it make a more structured project)
2 Wheels ( i got them from an old toy )
1 Switch
To power up this project i'll be using a 9 volt battery , but you can also use a A23 12 volt battery or any other similar power source ,you'll also need sodering tools such a sodering iron stanium , helping hands ,etc.
2 TIP120 Transistor
2 1k Resistors
2 1N4001 Diodes
2 LDRs
1 Switch
STEP 2: Circuit and Internal Structure
This is the diagram of the circuit i used . be carefull off the polarity of the motors and the position of the LDRs , because that defines the moves that the robot does .Before you proced to the next step , make sure that the motors spin in a correct way .There are no sodering instructions less than these , so you are free to make it in your way!!
STEP 3: Creating the Body
To make the body i used 2 old plastic circles , and i attached it with screws and bolts as it's show down there , but you can make the body you want , you could also use and od tupper .
STEP 4: Glue It Up
So now we are at the fun step , i glued the circuit to the body with the hot glue gun , i also added the wheels to the motors using it .I glued the LDRs to the top circle of the body , as it's showed in the image below .After you glued everything you'll have to put on the bolts to close the body of the robot ....
STEP 5: Finish !!!!
Now you are done !!! You've made a light seeking robot !!!!
I leave more images to show you more of my robot ,stay hungry stay foolish ....
17 Comments
Luigi Pizzolito 8 years ago
Cool!
If I get another motor I'll give it a try. :D
Here is some schematic with the SPDT Switch.
yhdesai 11 years ago
AM Robotics 10 years ago
AM Robotics 11 years ago
Michael_Bell 12 years ago
http://audiolabga.com/pdf/TIP30C.pdf
http://www.fairchildsemi.com/ds/TI/TIP120.pdf
Weiq 11 years ago
i can't understand you circuit diagram.
The_Weird_Human 12 years ago
AM Robotics 12 years ago
ajinkyadixit 12 years ago
Pranjal Joshi 12 years ago
i ll try it... bt TIP120 is easily available at here??? or suggest smthing els option
like npn or pnp.. :)
madbot1999 12 years ago
where did you buy yours?
but u have not shown the use of SPDT switch in the schematic.....pls give it
