Lightsaber
Intro: Lightsaber
Are you a Star Wars fan? Do you want to create your own lightsaber in the colour of your choice? This tutorial is made for you step by step we will guide you in this artistic realization. We hope you like the result ....
STEP 1: Supplies
- aluminium foil
- sheet
- paper towel roll
- buttons
- glue
- black tape
- scissors and rulers
-sheet of paper in the colour of your choice
STEP 2: Brush the Sheet With Glue
Apply glue evenly over the entire surface of the sheet, avoid piles of glue.
STEP 3: Aluminium Foil
Apply the foil to the sheet, once this is done, take a ruler. With this ruler you should now remove any relief from the foil.
STEP 4: Cutting
You can now cut off the excess aluminium from the foil.
STEP 5: Place Your Button
Place your button 15 cm from the bottom. If you wish, you can add other elements as you wish.
STEP 6: Size Adjustment
Cut about 8 centimetres off each side so that the two ends of the foil come together without overlapping around the roll.
STEP 7: Improvement of the Design
Glue 4 strips of 11cm black tape and place your little buttons as shown on the picture.
STEP 8: Creation of the Handle
Wrap the paper around the paper towel roll and close by putting glue along the height and then put tape around the roll as shown in the picture.
STEP 9: The Light Tube
With a sheet of paper of your choice of colour, form a cone. To do this, rotate the paper between your fingers to make a cone shape. Tape the cone shape and place it in the top opening and stick it on.
282186 2 years ago
