Introduction: Lil' Classic Bear
Do you always face difficulty sewing Amigurumi’s head to its’ body? Are you looking for a simple and cute pattern to make it into a lovely gift for your loved ones or yourself? Or are you simply looking for a bear to cuddle to bed?
If that’s so, Lil’ Classic Teddy is the perfect bear for you! He stands approximately 28cm tall and 21cm wide. Being the biggest amigurumi I’ve created, he is just about the right size to cuddle in your arms. He is also one of the simpler patterns I’ve created, which makes it an easy project to complete. This pattern is created in a way that both the head and body is crocheted together so it saves you time and effort from sewing them together.
Materials:
Yarn - Golden Brown, Light Blue and a bit of Dark Brown 8ply Acrylic Yarn
Crochet Hooks - Size 3.0mm
Yarn Needle or Normal Needle
Golden Brown and Light Blue Tapestry Thread or Yarn
Fiberfill
1 pair of 13mm Safety Eyes.
Stitch Marker or Safety Pin
Note: This pattern works in continuous rounds (instead of joined rounds).
Abbreviation:
MR - Magic Ring
sc - Single Crochet
2 sc in next sc - Increase
dec 1 - Decrease
Sl St - Slip Stitch
* * - Repeat Step
F/O - Fasten Off
Head and Body:
Golden Brown and Light Blue Yarn.
Starting with Golden Brown.
Rnd 1: MR, sc 6 in MR. (6)
Rnd 2: 2 sc in each sc around. (12)
Rnd 3: *sc 1, 2 sc in next sc*, repeat around. (18)
Rnd 4: *sc 2, 2 sc in next sc*, repeat around. (24)
Rnd 5: *sc 3, 2 sc in next sc*, repeat around. (30)
Rnd 6: *sc 4, 2 sc in next sc*, repeat around. (36)
Rnd 7: *2 sc in next sc, sc 5*, repeat around. (42)
Rnd 8: *2 sc in next sc, sc 6*, repeat around. (48)
Rnd 9: *2 sc in next sc, sc 7*, repeat around. (54)
Rnd 10: *2 sc in next sc, sc 8*, repeat around. (60)
Rnd 11: *sc 9, 2 sc in next sc*, repeat around. (66)
Rnd 12: *sc 10, 2 sc in next sc*, repeat around. (72)
Rnd 13-27: sc around. (72)
Insert Safety Eyes between Rnd 17 to 18.
Rnd 28: *dec 1, sc 10*, repeat around. (66)
Rnd 29: * dec 1, sc 9*, repeat around. (60)
Rnd 30: *dec 1, sc 8*, repeat around. (54)
Rnd 31: *dec 1, sc 7*, repeat around. (48)
Rnd 32: *dec 1, sc 6*, repeat around. (42)
Rnd 33: *dec 1, sc 5*, repeat around. (36)
Rnd 34: *dec 1, sc 4*, repeat around. (30)
Rnd 35: *dec 1, sc 3*, repeat around. (24)
Stuff head with fiberfill.
Change colour to Light Blue. (This is the start of the Body)
Rnd 36: sc around. (24)
Rnd 37: *2 sc in next sc, sc 3*, repeat around. (30)
Rnd 38: *2 sc in next sc, sc 4*, repeat around. (36)
Rnd 39: *2 sc in next sc, sc 5*, repeat around. (42)
Rnd 40: *sc 6, 2 sc in next sc*, repeat around. (48)
Rnd 41: *sc 7, 2 sc in next sc*, repeat around. (54)
Rnd 42-47: sc around. (54)
Rnd 48: *sc 8, 2 sc in next sc*, repeat around. (60)
Rnd 49-53: sc around. (60)
Change colour to Golden Brown. (Bottom half of the Body)
Rnd 54-57: sc around. (60)
Rnd 58: *dec 1, sc 8*, repeat around. (54)
Rnd 59: *dec 1, sc 7*, repeat around. (48)
Rnd 60: *dec 1, sc 6*, repeat around. (42)
Rnd 61: *dec 1, sc 5*, repeat around. (36)
Rnd 62: *dec 1, sc 4*, repeat around. (30)
Stuff body with fiberfill.
Rnd 63: *dec 1, sc 3*, repeat around. (24)
Rnd 64: *dec 1, sc 2*, repeat around. (18)
Add on fiberfill to stuff the entire body.
Rnd 65: *dec 1, sc 1*, repeat around. (12)
Rnd 66: *dec 1*, repeat around. (6)
F/O.
Arms: (make 2)
Start with Golden Brown
Rnd 4-7: sc around. (18)
Rnd 8-15: sc around. (18)
Rnd 16: *dec 1, sc 1*, repeat around. (12)
Rnd 17-22: sc around. (12)
Start stuffing arms with fiberfill.
Do not over stuff the top.
Rnd 23: *dec 1*, repeat around. (6)
F/O, leave a long end and weave it in and out to close up the hole.
Legs: (make 2)
Golden Brown Yarn
Rnd 6-12: sc around. (30)
Rnd 13: *dec 1, sc 3*, repeat around. (24)
Rnd 14-15: sc around. (24)
Rnd 16: dec 6 times, sc around. (18)
Stuff foot with fiberfill.
Rnd 17: dec 6 times, sc around. (12)
Rnd 18-29: sc around (12)
Do not stuff the legs.
Snout:
Golden Brown Yarn.
Rnd 6-7: sc around. (30)
F/O and leave a long end to sew to the head.
Ears: (make 2)
Golden Brown Yarn.
Rnd 6: *2 sc in next sc, sc 4*, repeat around. (36)
F/O and leave long end.
Fold circle in half and weave it in and out to close up the hole.
Do not stuff fiberfill.
Assembling: (Refer to picture)
Using a Yarn Needle, sew on teddy’s arms to the side of the body. One at each side.
Using a Yarn Needle, sew on teddy’s legs around Round 61 of teddy’s body.
Using some Dark Brown Yarn and a Yarn Needle, embroider a cute little teddy nose starting from the center of the snout upwards.
After completing, use a Yarn Needle and sew on teddy’s snout starting from approximately Round 19 of teddy’s head and sew it around.
Using a Yarn Needle, sew on teddy’s ears starting from Round 5 of teddy’s head and sew it downwards. Remember to sew it slightly curved towards the front to give a 3D effect.
(Alternative method of sewing: Using Golden Brown/Light Blue Tapestry Thread respectively and Tapestry Needle to sew the parts.)
And Congratulations, you’ve completed your Lil’ Classic Teddy!
This pattern is an original pattern by Rachel H of Little Yarn Friends (October 2012). Please do not claim this pattern as your own. If you wish to share this pattern, you may link to this pattern but please do not reprint it on your site. You may keep a copy for your own personal use but you may not sell or distribute it. Kindly inform and credit Little Yarn Friends if you want to sell items made from this pattern. Thank You.
Crochet, Amigurumi by littleyarnfriends
Click on the link to get Free crochet pattern of this teddy:
http://littleyarnfriends.tumblr.com/post/32656432256/crochet-along-pattern-lil-classic-teddy
Fiber Arts Contest
2 Comments
7 years ago
Heya! I'm just working on this cutie now.. Have hit round 13 and reading ahead it says to insert eyes between r17 & r18.. Do I go ahead and do all the rows and then insert the eyes with the backs once I'm a little bit further along so I can position them? Just trying to imagine how that will work. :)
8 years ago on Introduction
That is so cute!
