Line-Cook Knife Rack
Intro: Line-Cook Knife Rack
This knife rack will save you the $15.00 it costs to buy a more traditional magnetic strip style rack. It's super easy to make, looks cool, and will reward you everytime you head to the kitchen to make a nice dice of onion for your salsa verde. ps. I call it the "line-cook" because like me if you're a line cook in this city of abundant wealth (NYC) you're probably making about $10.00/hour and can't afford toilet paper after your rent.
STEP 1: Gather Your Supplies
This is so easy I only included these two steps. First get your supplies:
1) Two peices of birch verneer plywood or like matterial at a thickness of 3/4" ,length of about 18", and width of 3".
2) Two lag bolts that are at least 3 1/2" long and 1/4" diameter with 8 washers that fit onto them.
3) I used a a Japaneese pull saw and a combination suqare to make straight lines and cuts.
4) Before I intalled it I gave it a coat of Tung oil to keep it safe from splashing water, feel free to leave it untreated but some kind of finish will accent the cool endgrain of the plywood.
STEP 2: Drill 4 Holes
1) All you have to do now is drill two holes through both peices of wood, and two corresponding holes in your wall where you want to mount the rack.
2) For each lag bolt, sandwich three washers in between the wood slats (this is the space for the blades) and use one washer on the surface of the rack to stop the head of the bolt.
3) Thread the rack to the wall and enjoy a clutter free cuttin board.
11 Comments
The Rambler 11 years ago
To critical commentors: Instructables is all about sharing ideas that inspire, putting thoughts together to come up with brilliant solutions. There are many ways to improve things for your own personal use. If you're worried about your knives falling out of the sides than put the bolts at the ends of the wood and make one pocket in the middle. Though the design, as is, may be done so that you can easily remove and replace the knives. If you're worried about the washers dulling the blades replace them with plastic or wood spacers like some of the helpful suggestions below.
natille 14 years ago
And what about the sides? The knives could fall out if placed outside the lag bolts, falling behind whatever counter, stove, what-have-you you've mounted this above.
I like the simplicity, but it seems this could use a couple of revisions before prime time.
psycosis86 13 years ago
morfmir 17 years ago
b1russell 14 years ago
boognishmofo 15 years ago
theRIAA 17 years ago
karen608 16 years ago
spinach_dip 17 years ago
Doc Workingday 17 years ago
Robyntheslug 17 years ago
