Liquid Laundry Soap (Basic)
Intro: Liquid Laundry Soap (Basic)
This is a shockingly inexpensive way to make an effective liquid laundry soap. This is a very basic recipe, and easy to do; later I'll be showing a more advanced recipe that has more cleaning power than this one; however, please note, this laundry soap IS quite effective.
Ingredients:
14 oz. Bar of Soap
1/2 Cup Borax
3/4 Cup Washing Soda
Materials:
5 Gallon Bucket
Stick Blender
Food Blender
Cheese Grater
Small Pan
You can also make this recipe with a traditional "Fels Naptha" or "Zote" brand bar. Both work very well, however I prefer to use my homemade soap. If you happen to make some homemade soap and accidentally used too much Lye, making the soap permanently caustic... don't worry... it works GREAT for laundry. Just follow these instructions and put it to good use!
Grate the 14 oz. bar of soap into "Soap Noodles." Process the "Soap Noodles" into "Soap Particles" in your food blender.
Bring 6 Cups of water to boil. Add the 14 oz. of processed soap and whisk completely. All soap particles should be dissolved within 1-3 minutes.
Fill the 5 Gallon Bucket half way with Hot Water. Add the liquified soap, Washing Soda, and Borax. Blend the solution completely with Stick Blender. Fill the 5 Gallon Bucket to the top with warm water, and seal with lid.
After allowing the soap to rest for 12 hours you will be rewarded with a gelatinous liquid soap.
1/4 cup per laundry load yields good results. Don't be surprised if it sets up like jello, just stir it up, and it's perfectly fine.
Enjoy this inexpensive alternative to expensive laundry soaps.
Ingredients:
14 oz. Bar of Soap
1/2 Cup Borax
Materials:
5 Gallon Bucket
Stick Blender
Food Blender
Cheese Grater
Small Pan
23 Comments
always curious 8 years ago
Have similar recipe-but different method to get end product. I grate the soap, (THE HARDEST PART OF PROCESS) place in large saucepan, add about 2 litres water, heat and keep stirring until all the soap melts. Then I add the borax and baking soda and mix vigorously until all is dissolved. Then its tipped into large bucket (10 litres?) and warmish tap water added. Stir (I have a large wooden spoon for laundry use) until blended and leave to cool. Sometimes I add about 2 tablespoons of Eucalpytus Oil (it is strong!!) before the get sets. TO USE: about 1/2 large cup of gel dissolved in about 2 cups hot water (or in mason jar/shake) and that is tipped into machine after water fills-ensures gel is totally dissolved. For more severe stained clothes or grease on collars etc., , I just rub the areas with some stain -remover soap. THIS GEL SOAP DOES NOT PRODUCE SUDS! And good as a carpet stain remover (e.g., 2 spoons gel, 4 spoons hot water and rinse/blot after cleaning).
Cheap and easy to make, environmentally friendly and lasts so long - wonderful.
ACKNOWLEDGEMENT:(original recipe found many years ago on a "frugal" web site but cannot find it now.
CooperSPB 8 years ago
This is almost identical to the soap recipe I use for my laundry, and it works great! I use a 14oz Zote bar and shred/melt it and combine it with water in a 5 gallon bucket like you do except I don't add Borax to mine. I keep a jar of baking soda next to my laundry soap and add tablespoons accordingly as I wash; 2 Tbsp for normal loads, 3 Tbsp for my husband's work clothes, and 4 Tbsp for whites.
I'm looking forward to when I can use homemade soap like you- I wonder if it there is a noticeable difference in cleaning when using homemade soap or Zote soap.
skmblondie 9 years ago
Southernelle 10 years ago
I have a front load washer and it says to only use (he) products...will this work in mine?
masoon 10 years ago
IconicIdea 10 years ago
masoon 10 years ago
Okara 11 years ago
So I tried soapcal. No luck. But google asked if I meant www.soapcalc.com. Got it now. :)
Thanks so much for your tutorials, common sense approach and great sense of humour. Bookmarked now.
Okara 11 years ago
BlueFiskKnits 11 years ago
IconicIdea 11 years ago
Borax not only is a cleansing agent but also thickens the liquid soap, it's a main ingredient. Without it the soap will not thicken you you'll wind up with nothing more than soap water which can evaporate quickly and will not gel.
I've never tried this recipe with Baking Soda, but I highly doubt it will have the same effect, Baking Soda is a completely different chemical. With a different chemical reaction. Give it a try if you like. Lemon Juice or Vinegar? Vinegar would smell terrible and Lemon Juice would likely go bad. Give it a shot though, let me know if any of your methods work.
britsa 12 years ago
From wikipedia.com on borax:
Borax was added to the Substance of Very High Concern (SVHC) candidate list on 16 December 2010. The SVHC candidlate list is part of the EU Regulations on the Registration, Evaluation, Authorisation and Restriction of Chemicals 2006 (REACH), and the addition was based on the revised classification of Borax as toxic for reproduction category 1B under the CLP Regulations. Substances and mixtures imported into the EU which contain Borax are now required to be labelled with the warnings "May damage fertility" and "May damage the unborn child".[24]
MsJan 11 years ago
porcupinemamma 12 years ago
IconicIdea 12 years ago
Baking Soda: Sodium Bi-Carbonate
Washing Soda: Sodium Carbonate.
They are close chemically, but very different 'animals.' Like comparing a car to tractor.
dangerine 12 years ago
kowens 12 years ago
Borax, sodium tetraborate decahydrate, is not acutely toxic.[19] Its LD50 (median lethal dose) score is tested at 2.66 g/kg in rats:[20] a significant dose of the chemical is needed to cause severe symptoms or death. The lethal dose is not necessarily the same for humans. Sufficient exposure to borax dust can cause respiratory and skin irritation. (I would think for individuals working in the industry that produces Borax, they would need to be careful.) Ingestion may cause gastrointestinal distress including nausea, persistent vomiting, abdominal pain, and diarrhea. Effects on the vascular system and brain include headaches and lethargy, but are less frequent. "In severe poisonings, a beefy red skin rash affecting palms, soles, buttocks and scrotum has been described. With severe poisoning, erythematous and exfoliative rash, unconsciousness, respiratory depression, and renal failure." [21] A reassessment of boric acid/borax by the United States Environmental Protection Agency Office of Pesticide Programs found potential developmental toxicity (especially effects on the testes).[22] Boric acid solutions used as an eye wash or on abraded skin are known to be particularly toxic to infants, especially after repeated use, because of the slow elimination rate. (I think this is of concern if you are washing your child in a Borax solution, but not their washed and throughly rinsed clothing.) [23] Borax was added to the Substance of Very High Concern (SVHC) candidate list on 16 December 2010. The SVHC candidlate list is part of the EU Regulations on the Registration, Evaluation, Authorisation and Restriction of Chemicals 2006 (REACH), and the addition was based on the revised classification of Borax as toxic for reproduction category 1B under the CLP Regulations. Substances and mixtures imported into the EU which contain Borax are now required to be labelled with the warnings "May damage fertility" and "May damage the unborn child".[24]
My mother added Borax to Ivory Snow to keep my baby clothes clean because other detergents would irritate my sensitive skin. I think any one who is concerned needs to make sure that all of the Borax is dissolved and/or rinsed from clothes during washing.
britsa does make a valid point, if you are concerned about the chemicals that you are putting on your body or in your body, throughly research the information.
Shawn Stanford 12 years ago
It took about 20 minutes to make using stuff I had around the house (except for the washing soda, but that was easy enough to grab during a grocery run). I gave it overnight (about 10 hours) and found it had set up like jello. No problem: I stirred it up with a spoon and loaded some into an empty laundry detergent jug using a funnel. I filled my front-loader with the machine-recommended amount and let'er rip. It worked great and while I'm not ready to say it unequivocally, I think my clothes are cleaner than ever!
I don't expect that I'll ever buy laundry detergent again...
Penolopy Bulnick 12 years ago
