Live Cool
Intro: Live Cool
滑板是
极限运动历史的鼻祖。滑板运动扩展了许多极限运动。滑板运动是从1950年代末和1960年代初的冲浪运动演变而来,现已成为一种流行的运动。滑板的技能主要包括:空中技巧(在滑杆上),倒立技巧(在U平台上)和Ollie(随板起飞)。这些技巧可以说是除了翻转之外最重要的滑板动作。因此,滑板的变化及其自身风格也使滑板感觉更加丰富。
个性地图与
当代互联网名称的流行文字地图一致。恭喜,财富是人们的最佳祝福,也是滑板者的最佳游戏体验。底板的设计使用二维码,因为在二维码时代,用二维码向滑板添加朋友的方式会让其他人想起您。用夸张的底图是让您的信心飞涨。
加速结构的一侧有两个可放入灯光的孔。在晚上,加速结构更具风味。另一方面,有大的孔是单向的,因此应谨慎使用。
STEP 1: Step 1: Build Skateboard Surface
1.The
board is 81cm long, 20cm wide and 2.5cm high.
2. Punch 7mm diameter hole on the board
for the preparation of the later mounting base.
STEP 2: Step 2: Make Wheels
1.
The outer diameter of the wheel is 5cm, the inner diameter is 1.2cm, and some modifications are made.
STEP 3: Step 3: Make the Base
1.
The base plate is made of steel, which is 7cm * 5cm * 1cm, and the threaded holes to be connected, and then the bracket with buffer device and fixed wheel is connected
STEP 4: Step 4: Connect the Base and Wheel With the Skateboard
1. First link the wheel on one side
with the skateboard, and then mirror it to get the base structure of the other half.
STEP 5: Step 5: Fix the Scooter
STEP 6: Step 6: Design Acceleration Structure and Personality Map
1.
There are two holes on one side of the acceleration structure that can be put into the light. At night, the acceleration structure has more flavor. On the other side, there are large holes which are unidirectional, so you should use them carefully.
Penolopy Bulnick 4 years ago
