LoRa GPS Tracker/Pager
Intro: LoRa GPS Tracker/Pager
---A device that combines real-time location tracking and two-way pager, over a LoRa mesh network.---
I have been contacted by a number of people in search and rescue (SAR) who are interested in the other Ripple LoRa mesh projects I have been working on, and it got me to thinking about making a dedicated device for the field personnel.
Well, here it is!
This device doesn't require a companion Android handset, as it has a very simple UI for the user. It has a small OLED screen and just 3 push buttons, so only offers limited types of interaction with the user.
What it does
- Allows field user to set their status to one of 4 colors (Blue, Green, Orange, Red), which commander will see in real-time.
- Transmits user's location to commander in real-time.
- Alerts user of incoming messages and broadcasts from commander.
- Allows user to send a reply to incoming messages (from a list of options)
STEP 1: An Example Scenario
The admin of the network sets up the pager devices using the Ripple Commander application. Get it from Google Play: https://play.google.com/store/apps/details?id=com...
Using the app, the commander can see a list of devices on the mesh network.
STEP 2: Map View
The commander can see the status is now orange (see the orange circle above). They can also see the status AND location in the map view.
STEP 3: Messaging
Seeing the status of GeoPager1 change to orange the commander goes into chat screen, and asks if user needs assistance.
(NOTE: the reply in orange comes when the pager user selects a reply from the list)
To specify reply options, just enter "?:" with the options separated by "/"s
STEP 4: Pager Alerts
On the pager side, the field operative sees the green LED flash and buzzer sound.
STEP 5: Pager Interaction
They select the message preview with the top button, to see the message details.
The user then uses the buttons to select the reply option.
At this point the commander will get an alert that a reply has come in. (see the app chat screen above, with the orange reply)
STEP 6: How to Assemble the Devices
Refer to the wiring diagram above on how to connect up the buttons, buzzer and GPS:
STEP 7: Flashing the Firmware
You need to make sure you have the Arduino IDE installed, with the Espressif ESP32 boards support added. Go to the Ripple Github site for instructions:
https://github.com/spleenware/ripple
For this project, you need to flash this specific binary: https://github.com/spleenware/ripple#geopager-node...
NOTE: Unfortunately, the GPS uses the same UART as the built-in USB port, so you must disconnect the GPS whenever you are flashing the firmware OR programming the device via the app.
STEP 8: Configuring the Device (ID, Settings)
The Ripple Commander app has TWO launcher icons. For defining and configuring the devices on the mesh network, launch from the 'Device Provision' icon.
Tap on the 'NEW' menu in the top Actionbar. then enter a unique ID and name. Select 'GeoPager' in the Device Role drop-down. (optionally, you can set custom config with the '...' button)
Click on SAVE, then back on the main screen, there should be a new device in the list with the name you assigned.
Tap on the small 'computer chip' icon next to it to go into the 'Program Device' screen. While holding down the top button on the pager device (button A), connect a USB OTG cable from Android to the device which should power on the device. After a delay you should see 'PROGRAM MODE' on the OLED screen.
Now tap on the 'Program' button in the Commander app, and if all goes well there should be a '... done' message. The device should now have its ID, config and encryption keys stored in its EEPROM.
STEP 9: Initial Testing
Power off the device, then either attach the LiPo battery or power it from a USB source. Launch the main screen using the other launcher icon (labelled Ripple Commander). This should show the pager device in the list, with a gray circle next to it. The gray status means 'unknown' status, as the device hasn't had any interactions yet.
Tap on the pager device, to go into a 'chat' screen. The top Actionbar should now show the status circle update to BLUE, and the 'WiFi' icon next to it showing full/strong connection.
Try typing in some messages, which should make the pager beep/flash, etc
Donate
If you find this project useful and feel like throwing some Bitcoin my way, I'd be really grateful.
My BTC address: 1CspaTKKXZynVUviXQPrppGm45nBaAygmS
Feedback
If you are involved in SAR, or in some other organization with a command-and-control structure which could take advantage of this capability, I would love to help in setting up a trial project/deployment.
I continue to work on this project because it really engages me and interests me. I hope it can prove to be useful to the wider community. Feel free to message me here if you have questions.
Enjoy!
Regards,
Scott Powell
29 Comments
17dshaikh 1 year ago
john.pictin 3 years ago
LozC 2 years ago
This is to track me, dog, people etc.
There's a project on Hackster 'S.O.S enabled gps tracker' that you may be interested in. I have never coded so straight away have a long journey this winter.
john.pictin 2 years ago
sqij 2 years ago
LozC 2 years ago
Thanks again
sqij 2 years ago
I've recently added support for the TBeam boards.
sqij 3 years ago
Yes, this system works without any internet access. You would use an Android tablet running Ripple Commander to do the coordination. The transmit frequency is configurable, but is transmitted when the device moves at least some 'x' meters and at least 'y' seconds have elapsed. The devices don't record track of location, but I could add this. Regarding range, the thing that would improve this the most is to have a repeater device attached to a tethered helium balloon.
Leicester77 4 years ago
sqij 4 years ago
jgeepers 4 years ago
sqij 4 years ago
Deep sleep might be quite hard to implement on such a project but may give you a lot of additional battery life.
I love the 18650ies for their ease of use and availability from „dead“ notebook batteries, and a big plus is that they are easy to make „hot-swappable“.
Ellis Builds 3 years ago
My board is this one: https://www.amazon.com/gp/product/B076MSLFC9/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
The instructions for the board are here: https://github.com/Heltec-Aaron-Lee/WiFi_Kit_series
sqij 3 years ago
You can use that Heltec board for the 'Commander' radio, however. The GeoPager devices all communicate with the Commander, using the Commander app. For that radio, you would flash the Ripple-Bluetooth-heltech_v2.bin file (and connect using Bluetooth)
sqij 3 years ago
There might be a country restriction filtering it out. What country are you in?
sethpalenscar 3 years ago
