Loading Bar (Batch Programming)
Intro: Loading Bar (Batch Programming)
First copy and download my pictures for better view if isnt good now.
STEP 1: Step2.
Now just copy this code.
@echo off
color 0a
:Load
echo ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
echo Û°°° Û
echo Loading - 2%
ping localhost -n 2 >nul
@echo off
color 0a
:Load
echo Û°°° Û
echo Loading - 2%
STEP 2: Step3.
Adding a loop if you want. And what this does is basically just repeat the whole loading bar from Loading - 2%
Here's the code.
:loop
goto Load
Here's the code.
:loop
goto Load
3 Comments
HiPoweredHacker 11 years ago
SoulEater821 11 years ago
Prof. Pickle 11 years ago
May I suggest you update your code with a different perspective:
@echo off
setlocal enabledelayedexpansion
color 0a
for /l %%i in (1,2,100) do echo Loading - %%i^% & ping localhost -n 2 >nul & cls
::More code here
That should get the same output except for the fancy characters around it (I'm sorry if I'm upstaging you a little).
Also, a little tip, try including something like "DOS", or "Batch file" to the tags, so it's more easily found.
