Location Tracker With NodeMCU ESP8266
Intro: Location Tracker With NodeMCU ESP8266
Are you curious about how your NodeMCU can track your location? It's possible, even without a GPS module and without display. The output will be coordinates where you are located and you will see them in your serial monitor.
The following setup was used for NodeMCU 1.0 (ESP-12E Module) with Arduino IDE.
- Windows 10
- Arduino IDE v. 1.8.4
STEP 1: What Do You Need
What you need in order to follow this tutorial are the following components:
- Micro USB cable
- NodeMCU ESP8266
Furthermore, you will need:
- LocationAPI (from Unwired Labs)
- Acces to wifi or a hotspot
STEP 2: Go to Unwired Labs
Geolocation comes in very handy because when your GPS is down, you can still use Geolocation to track your location. Our host that provides geolocation, will be https://www.unwiredlabs.com/. Go to that website and sign up (the orange button in the upper right corner).
STEP 3: Sign Up to Get API Token
On the sign up page, you have to fill in your name, email (your API token will be send to your email) and use case (for example, personal use). Select your account type. The free version will do just fine, but keep in mind that you're limited and can't track your location 24/7. Let's get started!
STEP 4: Check Your Email
Go to your email and you will see your API token. Copy the API token, because you need that for the code we will be using. This is how the email looks like:
Hello!
Thanks for signing up with Unwired Labs LocationAPI! Your API token is 'your API code is here' (without quotes). This will give 100 requests/ day for free - forever.
If you'd like to track 5 devices for free, please respond with the following details and we'll upgrade your account within 12 hours:
1. Deployment type (Hardware/ App/ Other):
2. About your project:
3. Website:
You can login to your dashboard here: https://unwiredlabs.com/dashboard. If you run into trouble or have questions, reply to this email and I'll help you out!
Happy Locating!
Sagar
Unwired Labs
STEP 5: Libraries You Will Need
The next step is to open Arduino and go to manage libraries. You need to install the ArduinoJson library. The other libraries are already built in. When you're ready, you can start writing the code.
STEP 6: Add Code in Arduino to Connect With LocationAPI
Make a new sketch and add the following code in Arduino. Write your own wifi/hotspot name and your password. Paste the API token you received in the email. Upload your code to your NodeMCU.
#include <ESP8266HTTPClient.h>
#include <ArduinoJson.h>
#include "ESP8266WiFi.h"
// your network SSID (name) & network password char myssid[] = "Your wifi/hotspot name"; char mypass[] = "Your password";
// unwiredlabs Hostname & Geolocation Endpoint url const char* Host = "www.unwiredlabs.com"; String endpoint = "/v2/process.php";
// UnwiredLabs API_Token. Signup here to get a free token https://unwiredlabs.com/trial String token = "d99cccda52ec0b";
String jsonString = "{\n";
// Variables to store unwiredlabs response double latitude = 0.0; double longitude = 0.0; double accuracy = 0.0;
void setup(){ Serial.begin(115200);
// Set WiFi to station mode and disconnect from an AP if it was previously connected WiFi.mode(WIFI_STA); WiFi.disconnect(); Serial.println("Setup done");
// We start by connecting to a WiFi network Serial.print("Connecting to "); Serial.println(myssid); WiFi.begin(myssid, mypass);
while (WiFi.status() != WL_CONNECTED) { delay(500); Serial.print("."); } Serial.println("."); }
void loop() { char bssid[6]; DynamicJsonBuffer jsonBuffer;
// WiFi.scanNetworks will return the number of networks found int n = WiFi.scanNetworks(); Serial.println("scan done");
if (n == 0 ) { Serial.println("No networks available"); } else { Serial.print(n); Serial.println(" networks found"); }
// now build the jsonString... jsonString = "{\n"; jsonString += "\"token\" : \""; jsonString += token; jsonString += "\",\n"; jsonString += "\"id\" : \"saikirandevice01\",\n"; jsonString += "\"wifi\": [\n"; for (int j = 0; j < n; ++j) { jsonString += "{\n"; jsonString += "\"bssid\" : \""; jsonString += (WiFi.BSSIDstr(j)); jsonString += "\",\n"; jsonString += "\"signal\": "; jsonString += WiFi.RSSI(j); jsonString += "\n"; if (j < n - 1) { jsonString += "},\n"; } else { jsonString += "}\n"; } } jsonString += ("]\n"); jsonString += ("}\n"); Serial.println(jsonString);
WiFiClientSecure client;
//Connect to the client and make the api call Serial.println("Requesting URL: https://" + (String)Host + endpoint); if (client.connect(Host, 443)) { Serial.println("Connected"); client.println("POST " + endpoint + " HTTP/1.1"); client.println("Host: " + (String)Host); client.println("Connection: close"); client.println("Content-Type: application/json"); client.println("User-Agent: Arduino/1.0"); client.print("Content-Length: "); client.println(jsonString.length()); client.println(); client.print(jsonString); delay(500); }
//Read and parse all the lines of the reply from server while (client.available()) { String line = client.readStringUntil('\r'); JsonObject& root = jsonBuffer.parseObject(line); if (root.success()) { latitude = root["lat"]; longitude = root["lon"]; accuracy = root["accuracy"];
Serial.println(); Serial.print("Latitude = "); Serial.println(latitude, 6); Serial.print("Longitude = "); Serial.println(longitude, 6); Serial.print("Accuracy = "); Serial.println(accuracy); } }
Serial.println("closing connection"); Serial.println(); client.stop();
delay(5000); }
STEP 7: Open the Serial Monitor to See If You're Connected
Go to tools in Arduino and open the serial monitor. To see if you're connected to the internet, you should see the following in the serial monitor:
Setup done Connecting to (your wifi name) ... scan done
STEP 8: Get the Coordinates
If it worked succesfully, you should see under scan done a whole list of data. The only thing we need is the code under the requesting URL, so we will need the latitude and the longitude. These are the coordinates.
Requesting URL: https://www.unwiredlabs.com/v2/process.php
Connected
Latitude = 52.385259
Longitude = 5.196099
Accuracy = 41.00
closing connection
After 5 seconds the code will constantly update and you will probably see the latitude, longitude and accuracy change. That's because the API is trying it's best to track the location as precisely as possible.
STEP 9: Go to Google Maps
Go to https://www.google.com/maps/ and type your coordinates in the search bar. The coordinates need to be written in the following way: 52.385259,5.196099. Google Maps should show where you're located on the map.
STEP 10: Send Location to Your Mobile
And... You're done! Therefore, if you want to send the location to your mobile, it's possible. Google Maps will then send an email with your coordinates if you want to.
Happy locating!
44 Comments
sasi1783 4 years ago
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
kindly help me to solve this error please.
MahmoudA285 7 months ago
nithildass 3 years ago
please can anyone help
( that line in code )
(after this line , just paste)
client.setInsecure(); // 2
Eliezer D 1 year ago
I understand this code is a year old and I may be annoying by commenting but I have a school project that would really benefit from this and it is not working.
I first had trouble where it wouldn't print the longitude/latitude at all but adding the "client.setInsecure();" worked to fix that. The problem im now having is that even after raising the delay to 800ms, the long/lat are all 0.
I am on 115200 baud and am using ArduinoJson 5.13.
Any tips?
check if u are a new account
veritesiriwayo 8 months ago
that means , this is a new account , so check settings in unwired labs , wifi locating apì , u'll notice that it is not enabled
suriani husin 2 years ago
just keep connecting
as211 3 years ago
Connected
Latitude = 0.000000
Longitude = 0.000000
Accuracy = 0.00
what is the reason for this?
PriyanshS11 5 years ago
pdgraduation 3 years ago
and make sure you use baud rate 115200
client not declared in scope
RudeEngineer 3 years ago
SteenL 5 years ago
PCSnel 5 years ago
SteenL 5 years ago
PCSnel 5 years ago
