Lock Your Computer CPU Cabinet With Handheld Key
Intro: Lock Your Computer CPU Cabinet With Handheld Key
Prevent unauthorized access to your Desktop PC Tower. Keep it locked at home or office with a handheld key.
Follow the simple steps,
Level: Beginner
Tools Required
1.Key operated switch (50INR 1USD)
2. Jumper wires (From Scrap)
3. Terminal Connector (From Scrap)
STEP 1: Drilling and Connections
Open your Cabinet cover.
Take apart your FDD closure, make a hole with your drill machine of 12mm. Here I made a hole with my solder iron
Attach the Key operated switch with the wire hanging inside the CPU.
Put back the FDD closure.
As this closure is replaceable I drilled it here instead the whole cabinet
Find the pics attached
STEP 2: Making Connections
Connect one of your terminal CPU switch to one terminal of Key switch via a small jumper wire as shown
Solder the terminals as required
STEP 3: Connecting to Motherboard
Find the exact PowerSW terminal in the Motherboard and connect the rest two terminals to that corresponding MBD SW terminals.
STEP 4: BIOS Confiure to Keep in Stay OFF Mode
Configure BIOS by pressing DEL,F2 key (depends on ur PC)
Goto Power Options
Change After Power Failure to STAY OFF
This may vary from different BIOS to BIOS.
This is used to keep your PC switched off even when the electricity goes off.
Still key is required to switch the PC back ON.
STEP 5: Finish
Put your CPU Cabinet Cover back lock and screw it which cannot be opened.
Operate the Key-switch then the Power Button to turn PC on.
-Kumaran
kua201@gmail.com
18 Comments
CervezasE 8 years ago
If they really wanted to, couldnt they open the case, (I assume the case itself only has the regular thumbscrews and no lock) break the connection behind the wires and touch them together? seems like a system that isnt quite finished..
actionjksn 11 years ago
JamesW33 8 years ago
I've heard people refer to the whole box as the CPU. Using your car analogy, I think its along the same lines of people calling a car a "motor" (as in motor car). Also, as calling the computer a CPU is generally a marketing thing, it may originate from buyers assuming that a computer includes a monitor, keyboard, etc., and being miffed when they only receive the box and nothing else.
actionjksn 8 years ago
I'm 51 years old and have been all over the country and I have never heard a single person in my life call a car "a motor." I repair and build computers and read all the marketing stuff and I have never seen any company selling computers who refer to their computers in their marketing as a CPU. That doesn't even make any sense.
Any company who wants to get people to buy their computers would not want people to read or listen to their marketing and have people think that they don't know anything about their product. Because if they refer to their computer system as a CPU, then it would indicate that they really do not have any idea what they're writing about in their marketing. I'm not nitpicking here, the computer as in the whole tower containing the components is not called a CPU. And whoever refers to a car as a motor is saying something down right bazaar.
DevTheHam 8 years ago
rbennett8 11 years ago
and whats the power setting have to it ??
thehdp 11 years ago
Dr Qui 12 years ago
You need to hot glue the switch plate in place or use screws so the place cant be puled out or pushed in.
kumaran512 12 years ago
Dr Qui 12 years ago
slack-man 12 years ago
It's ironic that this used to be common on the earlier generation PCs, but I havn't seen it for a number of years..
Dr Qui 12 years ago
I was a PC tech from 95 -02 I only had a few PC's they user kept locked, It usually turned out that the guy with the locked computer had something grubby secret to hide.
I did use a lockable hard drive caddy from a Fujitsu machine as a hidden safe, my company removed to eliminate the change of some moron removing the drive, yes they where that dumb at times , I could tell some stories lol.
kc0kfg 12 years ago
Tkdwn 12 years ago
I would recommend using truecrypt to secure your data.
pavlus85 12 years ago
hcaz-301 12 years ago
Tanmay Das 12 years ago
