Longboard Rack
Intro: Longboard Rack
The Purpose:
I began building longboards (instructable soon to follow) and built so many at a time that I needed a rack big enough to hold a lot of boards, but to not take up a lot of space. Id seen racks that attached to the wall, but I wanted a standalone rack that could be moved easily.
STEP 1: The Supplies
1-2”x4”x8”
2- 1”x2’x2’ plywood squares
box of screws
black spray paint
STEP 2: The Design Step 1
This shelf was a quick design, very simple, but very useful. I determined that the two shelves needed to be 20” apart to accommodate for all sizes of boards. I cut 4 18” 2”x4” pieces (18” to accommodate for the two 1” boards).
I determined that I needed a hole of about 1 ½” to make the “shelf” part on the rack. I used a paddle bit, lining up the holes 8 inches in from the side to make sure the boards would sit in the shelf enough. I used our drill press to drill the holes nice and straight.
- I then used blue tape and taped from the hole to the edge at an upward angle to mark out where I needed to jig saw. I copied the angle all the way down and then cut them out. I used this first side as a guide and traced it onto the rest of the sides of the boards.
STEP 3: The Design Step 2
I went over the whole shelf with a light sanding, rounding over the corners where longboards would sit to keep them from getting scratched. Then I sprayed the whole shelf black.
STEP 4: The Final Product
I weight tested the shelf and it held 8 boards with ease. Its light enough to be easily moved around my workshop and was less than $20!
If you have any questions or business inquiries email me at raleighdavisup@gmail.com
