Introduction: Making Dr.Octopus Suit Based on Hydraulics
So we will make an octopus doctor's suit with piping for the sleeves and impraboard for the outside. we made it with Azka, Zaidhan, Ahmad and Alif. We also put lights on the hands claws and put the
battery to make the lights on. we use injection to make
the tentacles move. we also make the belt in the body of
the dr. octopus armor.We use two kinds of injection injection 10ml and 50ml.Hope you are interested!
Tools:
Electric soldering iron
Mini drill
Gas torch
PVC glue
Screwdriver set
Portable gas cylinder
Cable cutting pliers
Ingredients:
Impraboard
Color cable
10 x 10 copper sheet
8m hose measuring 14 mm x 10 mm
5m hose measuring 18mm x 14mm
8 10 ml injections
8 injections measuring 50 ml
Cable ties 2.5m x 200 mm
Paper insulation
Tin electric solder
Black spray paint
PVC Glue
PVC pipe
T PVC ½ inch 2 pieces
1 3.7 volt battery
1 3.7 volt battery holder
4 red 12 volt LED lights
Step 1:
1.Assemble the 4 claws required
with 8 injections measuring 10ml with hydraulics with a hose measuring 14 mm x 10 mm
2. Assemble the frame from PVC clothes
Step 2:
1. Arrange the sleeves of the doctor octopus shirt with 8 10 ml injections with hydraulics
2. Hose measuring 18 mm x 14 mm
Step 3:
1. Assemble the electricity for the Dr. Octopus shirt lamp.
2. Using the existing scheme. The electricity from the 3.7 Volt battery is connected to a DC step up to output 12 volts to light the 4 LED lights in each middle finger of Dr. Octopus' shirt.
3. Install a switch made of copper sheet.
4. Start trying it now!
Robotics Contest
