MIDI to WAVE - Windows Edition
Intro: MIDI to WAVE - Windows Edition
A while ago, I posted a Ubuntu MIDI to WAVE Converter. I have finally sat here and wrote a BATCH script (Windows) that can do the same. It wasn't easy as BATCH is weird. But I finally got it done. So here we go.
STEP 1: Requirements
You will need Zenity and Timidity. I assume you know how to set up Timidity. That is all you need. Well, a text editor, but you should already have that.
STEP 2: The Script
The script, apparently, doesn't support spaces in the filenames. I do not know why, and I do not want to fix it. But take the following code and copy/paste it into your text editor. Make sure to save it with a ".bat" extension under "All Files" or else you will have a text file. I also recommend saving it in its own folder.
|-----EDIT-----|
I have figured out how to fix the problem with spaces not being supported. I have updated the code to include these changes.
@echo off
if exist timidity.txt GOTO get_tdir
zenity --file-selection --directory --title="Directory for timidity.exe" > timidity.txt
:get_tdir
set /p tdir=
for /f "delims=" %%a in ('zenity --file-selection --title="MIDI File"') do @set midi=%%a
start /wait zenity.exe
IF ["%midi%"] == [] GOTO cancelled
for /f "delims=" %%a in ('zenity --file-selection --save --title="Save"') do @set save=%%a
IF ["%save%"] == [] GOTO cancelled
cd %tdir%
timidity "%midi%" -Ow -o "%save%".wav | zenity --progress --pulsate
start /wait timidity.exe
zenity --alert --text="Finished Conversion"
EXIT
:cancelled
zenity --info --text="Cancelled the Conversion"
STEP 3: How to Use the Script
The script requires a text file (.txt)(see below) to operate. When you first run the script, it will ask for where you where timidity.exe. The default location is "C:\timidity". Choose the timidity folder itself. If you installed timidity.exe somewhere else, choose it's folder. The chosen location will then be stored in a text file in the same folder as the script. If you chose the wrong directory, you can edit the text file itself or delete it. The script will always look for this file and create it should it not see it.
When this file exists, it will ask for a MIDI file to convert (I'm not sure if spaces are supported in folder/file names). Upon choosing one, it will ask for where to save the wave file and what to save it as. The ".wav" is appended automagically.
