Magnetic Monkey Fist
Introduction: Magnetic Monkey Fist
About: I am a Hobbyist maker.
Have you ever wanted to make a monkey fist? Have you ever wanted to make a magnetic monkey fist?
Well now is your chance to do so, with this easy to follow guide (At least that is my intent).
To start with you will need to get a couple of things,
First, you will need the magnetic core, I used a 1" round Magnetic buzzer toy
Second, you will need about 6' feet of paracord(Any color).
You will also need a lighter and scissors.
Step 1: Starting and Adding the Core
The first thing you will need to do is pinch one end between your thumb and ring finger after you do that wrap it around your ring finger and pointer finger four times.
Once that is done you will wrap it around horizontally two times, that is when you want to add the Magnetic core, After adding the core you need to wrap it an additional two times
Step 2: Securing the Core So It Can't Come Out
when you have done all of your horizontal wraps you will need to take the long end and thread it through the center, then bring it down on the backside and pass it through the bottom center.
after you have done that you can take it off your hand then do the remaining three wraps.
Step 3: Removing the Slack
Making sure to leave a 1/4 inch on the short end start one half-loop past the short end and pull till it is just snug, work your way around to the long end. I found going around twice got the snugness that I wanted.
Step 4: Finishing Touches
After you have tightened the paracord around the core it is time to cut the little tail off,
so cut it about 1/8 of an inch from the monkey fist then use the lighter to melt it so it does not fray, then use the flat part of your scissors to smash it against the monkey fist.
Step 5: Outro
And then voila, Your very own MAGNETIC Monkey fist is complete, If you wanted to you can do a simple loop on the other end so it can be used as a keychain.
I hope you found my first ever Instructable helpful.
Magnets Challenge
Magnets Challenge
Be the First to Share
    • 3D Printed Student Design Challenge
    • Retro Tech Challenge
    • Back to School: Student Design Challenge
    6 Comments
    DI_Prod
    DI_Prod
    1 year ago on Step 5
    Whats a monkey fist? / whats it for?
    and I hope I dont get banned for this but the loop at the end looks like a noose
    MarioG171
    MarioG171
    Reply 1 year ago
    The monkey fist is a knot, that sometimes is used as a weight or as a weapon for hand to hand combat, the name of it is because it looks like a small bunched fist/paw.
    And the noose that you mentioned, it may be used to get a metal keychain ring in there and so you can use the monkey fist as a keychain
    JustG3
    JustG3
    1 year ago
    This is actually pretty cool
