Introduction: Magnetic Chuck Wrench Holder (Drill Press)
Hello Instructables, I've recently purchased a new bench top drill press. After unboxing it and setting it up I noticed it didn't have a spot for the chuck wrench, so I created my own.
Step 1: Materials Needed
- Drill Press
- Magnet ( I got mine from old hard drives.)
- 5 minute epoxy
- Mixing utensil ( I used a Q-tip.)
- Scrap piece of wood to mix the epoxy on.
Step 2: Determine Where to Mount the Magnet.
Find an Appropriate spot for the magnet so It will not interfere with any moving parts.
Step 3: Mix the Epoxy
Mix the two part epoxy together, Then apply to the magnet.
I should have cut the cotton off the Q-tip beforehand.
Step 4: Add the Magnet.
Quickly add the magnet to the desired area. I used a second magnet to help hold the glued one in place.
Let the epoxy harden, I used 5 minute epoxy.
Step 5: Remove the Extra Magnet.
I let it harden for about 15 minutes before removing the front magnet.
Step 6: Done, Now Add the Chuck Wrench.
Finished I think it will work very well, The hard drive magnet is very strong so the wrench shouldn't come off while drilling.
As Always Thanks for looking.
Epilog Challenge VI
Glue Contest
