Gmail API Triggered Flag
Intro: Gmail API Triggered Flag
"Mail Man" is a simple arduino based gmail notifier. It leverages the gmail api along with arduino serial communication to allow the arduino to control a servo and hence wave a gmail flag when a new message is received.
STEP 1: Items for This Project
You will need the following items for this project:
- An Arduino. ( I used an Arduino Uno)
- A small micro servo
- 3D printed flag.
STEP 2: Flag
3D print the flag using the attached stl file. The servo from adafruit will come with 2 small screws that can be used to lock the flag onto the servo hand.
STEP 3: Code
Python
This project will use a python script to make calls to the gmail api and an arduino scrip that will activate the servo. The python script will recognize whether a new email has been received by comparing the most recently stored email_id (an identifier used by the api to differentiate emails). The script will make this check every three seconds. If a new message is received, there will be a discrepancy between the email_id stored and a message will be sent to the arduino to trigger the servo.
Arduino
The arduino will be listening on at a baud of 9600. If a new message is received, it will rotate the servo.
please refer to this git repo for code - Notification Code
STEP 4: That's It
Once the code is setup as mentioned in the repo, you should be good to go.
Think of creative ways of fastening the servo to your machine. I 3d printed a small hook (it is imperfect) and taped the servo to it. The hook is used to hang the servo on my screen.
Enhancement ideas.
- Package the arduino and servo in a small box.
- run a cron job to run the python script
- try using google apps script.
- use a raspberry pi instead of an arduino.
3 Comments
JustABrokenRobot 6 years ago
It would be better if could stay straight still because if you are out and leave the PC opened you will see it from far that you have received a mail, this project(im not saying it is bad i really like it and well done to you because you think about it and you must know that i vote it for both challenges)but this project is only if you ARE at the computer so you can see it go up and down :) Good job again!!!
sher10 6 years ago
Thanks for the suggestions. Will try and make a version with a raspberry pi or phone
Suisho 6 years ago
