Make Custom in Ear Monitors! (DIY IEM)
Intro: Make Custom in Ear Monitors! (DIY IEM)
Custom In-ear monitors (CIEM), widely used by musicians and performers. These earphones are custom fitted to the individuals ear for superior isolation and comfort.
It began when I wanted a pair of CIEM, just to realize that the cost for one has well surpassed my budget. So, I wondered if it's possible to make one myself and turns out there's a big community for DIY CIEMs! aka DIEM(DIY- IEM)
This Instructables will document the process of building your own CIEM at a fraction of the price :D
STEP 1: Tools, Materials and Some Literature
The tools and material will vary from each individuals preference.
This would be based on my quad driver CIEM
These are the general tools needed:
-Soldering iron
-Plasticine
-Blade
-Rotary tool
Materials
Electronics:
-Knowles GV-32830 (Quad Driver)
-Knowles BF-1861 (Green Dampener)
-Knowles BF- 1921 (Red Dampener)
-Litz wire
-2*3mm PVC sound tube
-1*2mm PVC sound tube
-Two pin 0.78mm female jack
-IEM wire
Shell:
- UV resin
- UV lacquer
- Ear Impressions
- Paraffin Wax
- Little Container
- Translucent silicone mold
- UV light chamber
- Dye
Note on impressions:
Making your own Impressions can cause potential risk of injury and deafness. It is suggested to seek an audiologist to do the impressions professionally. If you are to make your own, ensure that ear dams are used.
Note on Drivers:
The drivers used are already pre-made so there is no fuss on doing your own crossovers etc.
Alternatives and its suggested dampers.
Dual drivers:
Knowles GQ-30783, White damper
Knowles HE-31751, Brown damper on Tweeter, Red on Woofer
Triple Drivers
Knowles GK-31732, Green damper on Tweeter, Red on Woofer
Quad Drivers
Knowles GV-32830, Green damper on Tweeter, Orange or Red on Woofer
It is recommended to have a damper distance of 5mm for the tweeter and 7mm for the woofer as a starting point.
Here is a comprehensive guide on DIY CIEMs by user: Furco from head-fi.org : Click Here
STEP 2: Getting Your Impressions
I got my impressions done by an audiologist as the risk and cost for making the impressions by myself does not justify itself and I have a relatively small ear. But anyways here's a guide on impressions by AAW, a CIEM company based in Singapore. Images are by AAW and I do not own any of them.
Notes:
- It is recommended to use a biting block as this allows better movement of the jaw.
- Impressions have to pass the second bend of the canal
In picture 4, green indicates a good impression and grey lacking details
STEP 3: Preparing Your Impressions to Shape
I used a rotary tool and a blade to shape my ear impression. Ensure that the other surface is flattened.
After shaping it, clean it up and you can test fit by putting it back in your ear.
The ear canal at the second bend is highly sensitive so it's usually excluded.
Another good examples of how ear impressions are cut @ Post #3991(home-made IEMs) page 267 at headfi shows user: ForceMajeure's ear impression and user: Piotrus-g from CIEM company, Custom Art based in Poland indicating how impressions are cut.
STEP 4: Making Negative Mold of Impressions
Start by heating up some Paraffin Wax in a little tin until liquid and dip the impression for a few seconds and let dry, and then repeat again with a total of two light coatings. (or just one or completely exclude depending on preference) This is just to ensure a smooth surface, if it is too thick it might hurt or not fit well
I bought these little containers that allows the other end to be opened.
Place the impression at the centre. Heat up the silicone to temperature (differs between types, some uses a two part mixture to make the silicone mold). Slowly pour the silicone in to avoid bubbling. Allow it to settle and harden
STEP 5: Preparing the Balanced Armature Receivers
Solder the litz wire to the terminals. Don't be afraid it's actually not that hard! and then the other end to the female jacks. The tips of the female jacks can be trimmed to length.
Cut out the tubing for the dampeners.
x4 7mm 2*3mm tube to insert the dampeners
x2 5mm 1*2mm for the tweeters
x2 7mm 1*2 mm for the woofer
x4 3inch 1*2mm for the excess to bore
Set the dampeners vertically on the table and push the tube in. It can be further pressed in with your nails or a drill bit of a larger diameter can be used to push it in. The damper filter can be rather fragile so do be careful while handling
It is recommended to have a damper distance of 5mm for the tweeter and 7mm for the woofer as a starting point.You can play around with its position for different sound signatures.
STEP 6: Creating the Shell
Start by pouring in the UV resin to the negative mold(colloid). Place a black cover on the top to restrict UV light from flowing through as you only want the sides to be cure, making a hollow shell.
- Insert the mold into a UV chamber and let sit for about 1-3 minutes, varies on preferred thickness and light chamber. I like to have thin shells as they are easier to fit drivers if you have small ears. My cure time is about 1 minutes
- Pour out excess, do it slowly and allow all to fully drip out. Then put it back and allow it to cure again for about 2-4 mins
- Remove it from the colloid and putting using tweezers, avoid touching it as the surface is still tacky. Put it in a glycerin bath and cure it again while the shell is in the bath. Remove the shell and clean it up with water and some isopropyl alcohol.
And you are good to go.
*Cure time varies for everyone*
STEP 7: Installing Your Drivers
- Sand down your shells and making sure the faceplate surface is flat
- Start by drilling the holes for the tubes on your shell and grinding a slot for the connectors
- run the tube in first
- Attach tube to drivers
- Glue drivers to tube
- Pull the tube down in place
- Set drivers in place and putting drops of UV resin where the driver touches the wall of the shell and cure it to hold it in place
- Place the connector in its position and some drops of UV resin and cure to hold it in place
- You can test them out now at this point
STEP 8: Faceplate and Finishing It Up.
Proceed by covering it with a faceplate (wood, vinyl, metals etc) or make a layer of UV resin on a piece of glass or non stick paper place it over the shell and attaching them in place with more UV resin and cure. Trim the excess away and sand the entire shell down. Followed by a layer of UV lacquer and rotate the shell as it cures.
And you are done!
STEP 9: Parts List ~ish
Here are links to where I get my materials.
STEP 10: Special Thanks
Special thanks to the people of headfi (home-made-iems) and reddit r/DIEMs which have provided many useful guidance and information allowing me to build this. Be sure to check them out to seek for more help if needed.
19 Comments
cristian121313 2 years ago
Drummerboy06 5 years ago
Louis-PhilippeA1 5 years ago
I added a list with links to all material we used.
cdfleming 5 years ago
Can you please share which UV light chamber and resin you purchased? Thanks!
SuhD 5 years ago
Wow! Wonderful! Keep up the good work!
KBIduck 6 years ago
What molding material do you use?
Leave a link?
Thanks.
Luis Pinzón 6 years ago
Hi, could you tell me what is the "Glycerin bath" purpose?
jack ruby 6 years ago
Great 'ible!
I've been on that headfi thread since about 10 pages in, now it's 480! I had to stop subscribing to it :) Thanks for putting everything into one convenient instructible. I would love it if you put a list of your materials/suppliers so we can copy your great work. Thanks!
CCX191 6 years ago
Thanks!
Ah yes. I have now included the list on step 9 :)
Raleighup 6 years ago
this is amazing. Honestly have thought about this so much and someone finally did it themself!
CCX191 6 years ago
Thanks! I hope you will make a pair soon!
MichielB12 6 years ago
Hi! Can you tell me how you created the faceplate and how you did the final lacquering? With a brush becomes very ugly and when I dip it in Lacquer you have to stop the lacquer from going into the connector or the tubing. How did you do this?
CCX191 6 years ago
kschmidt2 6 years ago
This is great, I'm thinking about building some so I can listen to music on the motorbike, added benifit of not going deaf from wind noise.
sgsax 6 years ago
I bought my custom IEMs about 10 years ago and have been completely happy with them. Even though I could only afford the single driver model, they were the best investment I ever made in my performing (hobby) career to date. I found a company based in Florida that sells them at very low prices compared to your big name outfits. For this price point, though, this DIY solution is not extremely complicated and very doable by most people with a little bit of technical understanding and patience. I still have my ear moulds and I am very tempted to build a set with quad drivers following this guide and the reference document you posted from the head-fi.org forums. Thanks for sharing!
sorry to keep commenting instead of messaging but it wont allow me to direct message you. would you happen to have websites for all the supplies you bought?
CCX191 6 years ago
I can reply you from there :)
or PM me on Reddit u/ccx191
I can't seem to open my instructables profile page either.. so it's okay.
About how much did this project did this cost you? Im looking to see how much money I would save/whether its worth it
CCX191 6 years ago
