Make Glass Mirrors With Silver Nitrate, Sugar, Ammonia and Sodium Hydroxide
Intro: Make Glass Mirrors With Silver Nitrate, Sugar, Ammonia and Sodium Hydroxide
How to make a mirror silvering solution from silver nitrate, ammonia and sugar.
Glass surfaces can be given coatings of silver that make them into mirrors.
WARNING: Perform the whole experiment in less than two hours. This is because the solution generates highly poisonous silver nitride on standing. Also, the solution will give off ammonia when heated so you'll need to do this outside, in a fume hood or in a well-ventilated area. And wash away all chemicals with lots of water.
Get one gram of silver nitrate and one gram of sodium hydroxide. Then add enough water to both to completely dissolve them. Mix them together and youll get a black precipitate of silver oxide. Then add enough ammonia to completely dissolve the silver oxide. Add four grams of sugar and mix well.
The solution will deposit silver coatings when its heated. If you heat it in a glass container it will deposit silver on the inside of the container. To deposit it onto a glass pane you can put the glass into a tray with solution and heat the tray from below. But do not let the solution boil. Boiling tears the silver off the surface.
Thin layers of silver can be wiped off with a cloth if the silver goes where you don't want it. Thicker layers can be removed by applying hydrochloric acid.
This process produces a back reflective mirror, which is what most household mirrors are.
If you need to silver larger pieces of glass, or need thicker layers, just scale up the solution.
79 Comments
jbc1 4 years ago
I'm looking to put a thin coat of silver in a 3D printed tube so that it can be plated more quickly than using graphite paint (too much resistance).
Shawfish21 6 years ago
I want to use this for art purposes, can i use a latex material on the glass in places i dont want the mirror to be coated or silvered? And what the ratio formula for the amount or mixer? I see on here it looks like a 1gram:1 gram ratio with the silver nitrate and sodium hydroxide on here. So if i was doing a pane of glass the was 12"x12" , would my measurements be 12g:12gm or in liquid form 12ml:12ml?
rimar2000 15 years ago
NachoMahma 15 years ago
. aluminized mylar might work, but probably won't be very rugged.
NurdRage 15 years ago
Hamehr 6 years ago
There is a problem with Aluminum, As soon as you remove oxide from its surface, pure Aluminum react immediately with air, produce heat and form oxide quicker then you clean it. If you make a big chamber full of Nitrogen, you work inside with scuba mask and snorkel is going out of chamber. Then you will be able to polish Aluminum and protect the shining surface with some quartz coating.
mrwolfe 13 years ago
These processes are expensive to buy and set up, but not at all expensive to get done for you. From memory, spectra-chrome only costs a few dollars per square foot. Google "spray chrome"
Probably a bit late for you now, given the date of your post, but getting a mirror finish on Aluminium is very possible. I will be putting an instructable together very soon on polishing metals.
rimar2000 13 years ago
Kinnishian 15 years ago
https://www.instructables.com/id/SEOH3GFFABRWUOD/
