Make Pvc Pipe Cage - Pvc Projects
Intro: Make Pvc Pipe Cage - Pvc Projects
In this tutorial I am going to make PVC pipe cage by using pvc pipes of the length of 1 inches which is a normal pvc pipe for water supply but can be use in a lot of projects , making pvc cage by using pvc pipe is simple and easy project.
STEP 1: Making Joints
Join all the pvc pipes to 3 way elbows making a square shape
STEP 2: Putting Net
put meal net over the structure , it will be easy if it is cut by it's size to form on all it's 4 sides covering in one piece.
Tighten the net on all it's sides by pvc so it stays strongly and doesn't move from the structure.
STEP 3: Make Door
Take 4 elbows and make a square shape ,put the net over it and tighten it with the cable ties.
STEP 4: Place Necessary Things
Put the door hinge on the door and structure and tighten it with the screws ,make hole for door knob and set it up , place the door lock and put it on with screws.
STEP 5: Making Base
Place the plyboard on the bottom side which we didn't cover by net , tighten it with the screws on the bottom structure of the cage.
The cage is ready for bird,rabbit,cat etc
If you like this tutorial Please like share and vote
