Introduction: Make Your Ideas With Laser Anywhere-Make Pen Holder
Material:3mm plywood
Laser head:standerd head
Thunder laser used:
Model: Nova 35 laser cutter machine
Laser Tube: 80 watt
Step 1: Setting Parameters
Processing Mode: cut
Speed: 20mm/s
Max power: 60%
Min power: 70%
After we design the file in CorelDraw, we send the file to laser software directly by clicking the laser plug-in. Then we input the best setting parameters and “Download” the file to the laser cutter.
Step 2: Start Cutting
Place the wood sheet on the machine working table, move the laser head to the right start position, adjust the focal distance, press “Origin” button to set the starting point, then press “Start” to run the job.
Step 3: Assemble(finished)
After the laser cutter finish working, take out the pieces and put them aside.then,last step,Start assembling triceratops.
Step 4: Work Show
Well done the pen holder , as long as you turn on the switch of laser cutter, You can Find a nice home for your pen. Enjoy it!do you like it?
