Make Your Ideas With Laser Anywhere-Make a Brave Triceratops Together!
Introduction: Make Your Ideas With Laser Anywhere-Make a Brave Triceratops Together!
About: Laser professor
Using laser cutter to make a brave triceratops.
Step 1: Required Items
Material:3mm plywood
Laser head:standerd head
Thunder laser used:
Model: Nova 35 laser cutter machine
Laser Tube: 80 watt
Step 2: Setting Parameters
Processing Mode: cut
Speed: 20mm/s
Max power: 60%
Min power: 70%
After we design the file in CorelDraw, we send the file to laser software directly by clicking the laser plug-in. Then we input the best setting parameters and “Download” the file to the laser cutter.
Step 3: Start Cutting
Place the wood sheet on the machine working table, move the laser head to the right start position, adjust the focal distance, press “Origin” button to set the starting point, then press “Start” to run the job.
Step 4: Assemble(finished):
After the laser cutter finish working, take out the pieces and put them aside.then,last step,Start assembling triceratops.
Step 5: Work Show
Well done the Triceratops , as long as you turn on the switch of laser cutter, You can make a triceratops by yourself. Enjoy it!do you like it?
Be the First to Share
    • For the Home Contest
    • Make It Bridge
      Make It Bridge
    • Game Design: Student Design Challenge
    2 Comments
    PhotoMaster
    PhotoMaster
    8 months ago
    Looks amazing. Can you share the file in SVG format?
    sixhalfdozen
    sixhalfdozen
    Question 4 years ago
    Is the vector file available for download?
