Make Your Own Dimmable LED Workshop Lighting!
Intro: Make Your Own Dimmable LED Workshop Lighting!
In this Instructable, I'll show you how to make your own extremely efficient LED lighting for your workshop!
We, Makers, Never have enough lighting on our worktable, So we need to buy lamps. But as makers, We don't buy things (And get ripped off...), We MAKE them! That's why I've decided to make my own LED lighting!
Let's get started!
Update: Please see several of the comments below. While diodes do work for this project, they aren't the best option.
STEP 1: What You'll Need
Materials:
8 Pieces - 12V 10W LED's
Wire
Heatsinks (Salvaged)
9 Pieces- SR540MIT Diodes (Or equivalent)
Heat-Shrink Tubing
Clear "Duck" Masking Tape
Rocker Switch (Salvaged)
Tools:
WAVE- The Ultimate Helping Hands Vise (MUST!!!)
Utility Knife
Tripod
Permanent Marker
Electronic // Power Tools:
Why: I need more lighting!
Protection Gear Needed: A Ventilated Area
Cost (for me): <$5
Needed Skills: Soldering on a PCB, Using Diodes, Hot Gluing
Approximate Time: 2-3 Hours (It took me waaay more, But you already have instructions...)
STEP 2: The Backstory & Plan
About a month ago, I attached the "LEDPOD" (Yes... I removed it from the tripod) to the cabinet that was over my over desk cabinet. While I did have LED strips on the cabinet, They weren't strong enough for working with small electronics or for photographing them.
I thought that I could attach my LEDPOD to the cabinet, And I did, But there were a several problems:
1. It was ugly
2. It blocked my reach for the small screwdrivers that were on my Ultimate Magnetic Pegboard (Because it was big)
3. It wasn't strong enough (Not enough Lumen)
4. The light has a green tint (Low CRI, I believe)
5. It had a noisy fan (To cool down the LED Strips)
6. It had a really bad dimmer (I used resistors to dim the LED's brightness, I didn't know 12V HF-PWM dimmers existed when I made it)
Seems like there are enough reason to replace it, Right?
So what I wanted to make had to be:
1. Thin & Small ✓
2. Powerful (High Lumen output) ✓
3. Have no green tint, Thus having a "clear output" ✓
4. Won't heat up, Thus not needing a fan & a big heatsink, Which won't make any noise ✓
5. Has a High Frequency PWM Dimmer (No vertical dash line flickers on the image) ✓
6. A dimmer with many dimming options ✓
7. Low cost to make ✓
8. I'd be able to make it without a multimeter (Because my multimeter died) ✓
My plan was to use 12V 10W Cool-White LED's (Since they're only $0.27 each!), And undervolt them so the won't heat up. I planned to use Diodes to lower the voltage.
Because I lowered the voltage, Each LED wasn't as bright, So I had to use more LED's. Even though I used more LED's, The total price was still cheaper because I didn't need to buy any big heatsinks.
After experimenting (A lot!), I decided to put 9 Schottky Diodes in series with the 8 LED's (That were soldered in parallel). This lowers the voltage to the point where the LED's give out the maximum efficiency (From my experiments). The LED's get only a bit warm, Meaning that they need a small heatsink, But still produce a lot of light
Sadly, As I wrote above, I don't have voltage measurements because my multimeter died. On the other hand, What's Inside coming soon!
STEP 3: Install the Diodes on the PCB
As I mentioned before, I decided to use 9 diodes. I placed them on the breadboard in series and soldered them.
I later the legs of the diodes with wire cutters, And then used a utility knife to score and snap the breadboard to the right size
In case you haven't seen my Instructable about it, This is the helping hands device that I used
STEP 4: Glue the Heat-Sinks Together
I found some nice Heat-Sinks in my box of Heat-Sinks, And decided to use them (I believe these were salvaged from a Flat-Screen TV)
I smeared some 2-Part Epoxy onto the fins of the Heat-Sink, And let it cure. Make sure to do this in a ventilated environment, As the fumes aren't particularly healthy to breath in
STEP 5: Attaching the LED's to the Heat-Sink W/ Thermal Adhesive
I first started by planning the distance that I wanted to have between each one. I wanted to keep 1.5 cm (0.6") away from the edge of my 31cm (12") Heat-Sink. My calculations showed that I needed to keep about 1.8cm between each one (0.7").
I applied* the Thermal Adhesive onto the back of each LED, And the clamped it down tightly, With transformers that is... :)
Note: Place all of the LED's in the same direction: +to+ and -to-, This will make the soldering process (Next step) way easier
*Here is a great video that shows how to apply Thermal Paste/Adhesive
STEP 6: Solder the LED's Together in Parallel
First, I started by pre-tinning all of the contacts on the LED's
Next, I removed the outer sheathing from some fairly thick wires
Lastly, I soldered all of the LED's in parallel, This is pretty easy to solder
STEP 7: Attaching the Heat-Sinks to My Over-Table Cabinet
I used a tripod to hold and align it perfectly to the place that I wanted. This way is easier than holding it in place
I used Clear "Duck" Masking Tape to attach it to the cabinet, Make sure to remove all of the air bubbles while applying the Tape. For the back, I used blue Painter's Tape, Since it was easier to apply and is hidden from sight
STEP 8: Solder the Power Supply to the Dimmer
I first started by chopping off the Power Supply's connector, And removing the insulating sheathing from the wires
After that I soldered the + of the Power Supply to the + of the Dimmer's input. Same goes with the negative side. I finished it off by insulating the wires with shrink tubing
STEP 9: More Soldering...
First, I started by soldering the + of the Dimmer's output to the to one of the Diodes +
Next, I soldered a grey "jumper wire" to the - of one of the Diodes (aka the "Output")
I finished by soldering the - of the Dimmer's output to the - of the LED's, And the grey jumper wire to the + side of the LED's
This is a bit hard to explain, But hopefully the pictures help :)
STEP 10: Adding a Switch
I kind of failed at not doing this earlier, But I forgot to add the switch. Oopsie :)
I had to cut the middle of the positive input of the dimmer, Tin the wire, And solder the switch. As shown in the pictures
STEP 11: Gluing the Electronics to the Cabinet (And You're DONE!)
To tidy everything up, I hot glued the Dimmer and the Switch to the cabinet, And tucked the Diodes' PCB behind one of the wires.
No more mess!
(Oh, And by the way, You're DONE!)
Don't forget to Follow me on Instructables, I have over 60 Instructables that I'm sure you'd like!
And Votes... Are always appreciated :) Thanks!
Want some example pictures? Here you go!
197 Comments
Yonatan24 7 years ago
See GautierA's version: https://www.instructables.com/id/LED-Ramp-8x50-Watt...
asimobot 7 years ago
Yes. If you don't use a heatsink, the LED will overheat, which might cause it to overheat.
RANDOM KNOWLEDGE 7 years ago
and try to put the pcb boxed in or somthing, before somthing happens. so that you dont have exposure of any copper or metal.
FRIEND, I ALREADY HAVE CHECKED IT OUT 1 WEEK AGO.
is nice
Also in that IBLE you still you have problems with the DIMMERS i saw eeh, nice things to do forums for.
if you need help, ask.
Awesome! I forgot that you were one of the members that commented!
I don't need any help with the dimmer. I'm waiting for a different one to arrive from eBay :)
I don't think that's necessary. Everything was pretty small, and fairly organized...
you know its 80 WATTS on 12V
and not very cost effective.
(but you say you pult the voltage down" to what? so WHATS THE WATTS haha
but eeeh who am i to judge. its nice and cooooool
Thanks. I don't use this anymore. I've turned it into something else.
I don't remember all of the details, but if you're looking for more information, see some of the older comments that I posted...
its 60WATTS
you say there you had 12V on 5A thats ( P=IxU= I=5a x U=12V=P60Watt
P= Power (watts)
I= Current (Amps)
U= Electricity (Voltage)
so if you know 2 of the 3, then you always can come to the outcome of the 3th
but then you also must know the ( Ohms Law ) for even more helping to come to all answers
but stil i am confused,
you say VOLTAGE resistors not CURRENT, to bring the voltage down.
but its stil 12V
but you have less current.
opleace explain better for everybody if possible.
Exactly. Other members have pointed out that I had done this incorrectly.
Sorry, but I don't remember all of the info. If you're looking for a cool LED project, I recommend checking out my new Instructable on How to Make an Articulating 70W Spectrum-Balanced LED Panel :)
RalphB32 7 years ago
good idea but a bit messy, you could have tidied it up a bit like putting the electronics into a box.
Not sure about "messy", everything is pretty small.
Or should I say was? I've turned this into something else now... :)
Mjtrinihobby 7 years ago
impressive build and neat!
Thanks!
(For some reason, I didn't get notified of your comment...)
BunceyTheInbred 7 years ago
I know the pain of a dead multimeter when you need to get something done. It's like having a limb chopped off.
Great project as well! Exactly what I needed for inspiration and direction.
Almost :)
Thanks! I don't know if you saw any of the other comments, But you should (recommended) use a "Step-Down DC-DC Converter" instead of the Diodes. You can buy one for a little over a $1 on eBay.
At first when I glanced over the project I wondered why you chose the diodes and thought it was maybe because you are likely to have them lying around.
Hope you produce more cool and handy stuff.
Yup!
Glad you liked it!
