Make Your Own Flashing Lights Freeform Sculpture With a 555 Timer
Intro: Make Your Own Flashing Lights Freeform Sculpture With a 555 Timer
As always, you have 2 options you can either watch the video above or follow this instructable to create your very own flashing lights freeform circuit sculpture.
The 555 timer IC is an 8-pin integrated chip that is used in a variety of timer, delay, pulse generation and oscillator applications. It is known as one of the most popular integrated circuit ever made.
Now this sculpture is a bit of a challenging one, as we will be using a smaller package (SOIC-8) 555 timer. However, the template provided will help you.
It may look a little hard but with some time, patience, and the right tools it is definitely possible.
STEP 1: Circuit Diagram
First with the basics, if you would like to virtually test the circuit and play around with the components. You can follow the link to the Tinkercad Circuit here: https://www.tinkercad.com/things/jaZdfGmCIl7.
The design is based on a schematic from here: https://www.555-timer-circuits.com/flashing-railroad-lights.html
If you want to adjust the speed of the flashing lights you will need to change the value of the capacitor.
STEP 2: Using the Template
There are multiple copies of the circuit on the same page, I prefer this as it allows you to use 1 template to measure the brass wires and the other template can be used in conjunction with doublesided tape to make and hold the circuit sculpture.
The template also contains the circuit from the front and back view. If you decide to use the front circuit template the soldering is a little easier, however the soldering will look a lot nicer if you use the back circuit template as the soldering joints are all hidden.
There are multiple templates which also helps when you mess up the circuit :D.
STEP 3: Placement of Components
So, this is where the templates and the double-sided tape come in very handy.
Secure the small SMD components to the template and ensure that the polarity of the LEDs and the capacitor are correct.
STEP 4: Soldering and a Lot of Patience
Take your time at this stage and use some flux to help with the soldering.
I would also recommend holding down the components with a set of tweezers, so they don't move when you are soldering.
The first time I tried to build this, my soldering was not great and it didn't work so I made a second version which finally worked and also looked a lot nicer.
STEP 5: Battery Connection
I am powering the entire circuit with a 9V battery. But just wanted to share how I took the photo and how the little sculpture was powered with the 2 brass wires from the side.
STEP 6: Finish
That's all!
I do have to agree this is a little challenging, but it is a lot of fun. If you do make your own do share them here. You can also try to follow this guide and make something similar without using all SMD Components.
19 Comments
JimM90 1 year ago
4dcircuitry 1 year ago
PRETINHO 1 year ago
ELECTRONFLYER1 1 year ago
Mad4400 1 year ago
The design is based on a schematic from here: The design is based on a schematic from here: https://www.555-timer-circuits.com/flashing-railr...
IVT 1 year ago
Crafty platform for electronics 1 year ago
jdg5111 1 year ago
The middle resistor is a 47KΩ Resistor.
The value of the capacitor can vary and this will effect the frequency of the blinking. I am using a 22uF Capacitor. (Increase the capacitance to increase the delay between the Flashing)
ak08820 1 year ago
2. Could you use a variable capacitor to make the flashing rate changeable? Or some kind of circuit so that the flashing rate changes by itself?
1. Yep you should be able to power the circuit with a 4.5V source (Even 3*AA battery) I don't see any problems with it. Do let me know if you give it a go with a USB powered version (I may give it a go as well with some other circuits in the future).
2. I personally haven't played with a variable capactior on the circuits (it should work). To change the flashing rate by itself it would require some further components, which would make the circuit a lot more complicated to make.
turtlewax 1 year ago
I will have to give it a go on the next little circuit that I am making.
hdreiling 1 year ago
I built it in the 90s with throgh hole parts.
