Introduction: Make Your Own Fog Juice
Make your very own fog juice that is cheap and very effective!
All you need is a few things.
• Distilled Water
• Glycerin
• Container (empty bottle)
• Fog Machine
• Measuring Cup
Step 1: Distilled Water
Distilled means that there are no minerals in the water. Those minerals build up in small pipes and tubes, such as in a fog machine.
Please buy distilled water for this.
Step 2: Mix Water & Glycerin
Very Thick Smoke:
30% Glycerin | 70% Water
Thick Smoke:
20% Glycerin | 80% Water
Less Thick Smoke:
15% Glycerin | 85% Water
Step 3: Store in a Container
Store your final solution into an empty, clean container. Make sure to store all unused fog juice is stored properly. Keeping fog juice in the fog machine can also cause impurities to grow in it, ruining it and potentially the machine.
Halloween Decorations Contest
2 People Made This Project!
- Velis666 made it!
- Stargazer0506 made it!
49 Comments
7 years ago
Is that vegetable glycerin or polypropelene glycol?
Reply 1 year ago
PG is poiso
Reply 3 years ago
Veg
2 years ago
What if i want to convert a hydrogen peroxide (H2O2) solution into fog? Do i swap the water in your formula wtih H2O2?
for example:
Very Thick Smoke:
30% Glycerin | 70% H2O2 solution ?
will this work? My purpose is to disinfect rooms in my house against covid.
Reply 2 years ago
Well, using H2O2 would not work well because it has plenty of safety hazards. Inhalation of household strength hydrogen peroxide (3%) can cause irritation to your eyes, skin, and respiratory system.
Reply 2 years ago
Don't use hydrogen peroxide, mix liquid sanitizer 20% + 20%Glycerine + 60% Water. Don't use much glycerine for Sanitizing purpose.
Question 2 years ago on Introduction
What steps can be used to make oil based haze fluid
Answer 2 years ago
I added essential oils to my juice and as long as you clean the head of the fog machine it works well.
7 years ago
hello. would adding a food coloring or some sort of scent, change the color or smell of the fog. and also, would it be possible to take this liquid put it into a container, and then like drop in something redhot and have same effect?
Reply 3 years ago
Scented oils would work for smell but for color. Do not add anything like food coloring. It will ruin your machine. You need to use light under the fog to produce an effect safely
Question 3 years ago on Step 2
Hi how can you convert glycerin and distilled water into a thick fog? What element and cotton are you using
Answer 3 years ago
This is not for vaping!
What kind of glycerin is used for thick fog? Which smoke does not smell?
Answer 3 years ago
Go to any pharmacy and ask the pharmacist. They will show you which one is safe. Its the glycerin thats good for chapped skin
3 years ago
Probably not a good idea to put bleach in your mix if storing it. Just make more or store with a tight lid for reuse. Remember folks..It is cheap to make.
3 years ago on Introduction
I realy appreciate this info. My wife and i own a burlesque dinner thester called the boom boom room stl in St Louis. I run lights and sound. I need a ton of fog. The place was a smoking bar and the ac units really move and vlean a lot of air. However. Humbly I say. This did not work for me. Considering it just Glycol and distilled water im thinking I may have got the wrongs stuff. I got the food grade kind. So. It smokes. But it disappears in a about 15 seconds like the quick disappearing kind for guisers.
10 years ago on Introduction
Minerals do not cause water to become stagnant. You are confusing bacteria & minerals. The reason it's called diSTILLed water is that it is run thru a STILL as stated by wnnorton. boiling will only concentrate the minerals as the pure water escapes as steam. ( I work in the film industry & repair fog machines as well as many other types of equipment). Most of the fog fluid used in professional setups is based on a non-toxic substance similar to anti-freeze (glycol based). DO NOT use anti-freeze,it IS TOXIC !!
Other than that great instructable !!
Reply 4 years ago
That steam from the boiling water is your distilled water...you just have to capture the steam and you have distilled water. Propylene Glycol can be used as well as glycerine..both of these are the same ingredients the vaping,/e-cig industry uses to carry the flavor and "smoke" effect of electronic cigarettes. I doubt adding food coloring would change the fog color or I'm sure you would see vapers blowing out blue and pink clouds..I have been told certain flavors from my e-cig smell good and occasionally I'm told one stinks so scented fog is something to play around with. I have used lavender oil at three or four drops per quart and this works great.
4 years ago on Step 2
Dry ice in small bundles wrapped in silk or thin cotton and placed low will help keep the home made fog near the ground and slow dissipation.. we used it this way for our band effects.
4 years ago
I’ve had an issue with bacteria forming in my fog machines. It says to add a small amount of bleach to the solution. Is that okay to do even though it’s being heated? Breathing bleach seems like a bad idea, but maybe if it’s a benign amount it’s not as bad?
