Make Your Own Sandblaster and How to Use It
Intro: Make Your Own Sandblaster and How to Use It
Need to make your blue jeans more stylish? Want a gorgeous frosty finish on metals or glass? Want to paint to stick to something? Mr. Sandblaster is your answer! Make one today - it's really easy! Here's how:
The sandblaster in action, frosting a test-strip of copper for one of Tetranitrate's secret projects.
STEP 1: Materials
Sand gets everywhere, unless you do this all inside an enclosed box.
Sand got in my nose, between my teeth, ears, and despite the goggles, my eyes. When this was done, I looked sparkly from all the garnet sand dust on my face. Consider wearing a bandanna, especially if you have any respiratory issues. Actually, you really want to wear a respirator, to avoid silicosis. Use goggles if you have them. Swimming goggles (that seal over your eyes) or a snorkel might work best.
To construct the sandblaster, attach the hose to the air gun, and drop the other end into a bucket of garnet sand or other abrasive. Any even-sized abrasive should work - we grabbed this out of a pile of abrasive meant for the water jet.
Once everything is assembled, proceed to sandblast!
My jeans are indeed whiter.
STEP 2: Making the Sandblaster
The setup is a normal air gun, with a hose at a second attachment. This sucks in sand at a constant rate, via Bernoulli's Principle, like an aspiration setup in a chemistry class.
Find a bucket of sand for the hose to rest in. Find some good method to keep the hose submerged in sand, like duct-taping the hose to the side of the bucket so that it's always pointed downwards.
We just tipped the bucket so the sand was in a huge pile on one side, and stuck the hose into that. Even so, every now and then the hose stops sucking sand, which sucks.
Hook the gun up to any compressor hose.
STEP 3: Sandblasting
See what materials work!
Tetranitrate draws a smiley face (and subsequently, a frowny face) on his pants:
I sandblasted my jeans because I am struck by what a ripoff it is to pay $60 for sandblasted jeans.
The tshirt I sandblasted didn't change colors, but it felt thinner in that patch.
Later I sandblasted "DIY" onto the back of my left pant-leg. The intersection at the forks of the "Y" actually burnt/blasted through, giving it that rough, well-worn look. Want ripped jeans? Just sandblast them a little more.
Otherwise, metals are great, so is glass (especially glass - you can mask and sandblast wine glasses, or just give a frosty finish to anything you're working on.)
Industrially, sandblasting is used to evenly rough a surface before it is painted.
Also, don't do what I did! Take off your jeans if you want to sandblast them - my leg felt burnt for a few hours after blasting them.
(all the same, it was a blast - I didn't take them off because this was impromptu and I couldn't, y'know, take them off there in public and all..)
76 Comments
woomyse 15 years ago
The title is a bit misleading; it says "Make your own sand blaster, And how to use it" Clearly you did not make your sandblaster, it looks like it came from Harbour Freight. You used it, but not safely, and could possibly mislead others. Thanks to ironsmiter for the tip on baking soda, and ditto wasp's sentiments.
disturbedreaper 15 years ago
Dennis Jones 12 years ago
Derin 15 years ago
Callum Snowden 12 years ago
janisalnis 6 years ago
Please describe what part You added to the pistol.
MCRUELMASTER 6 years ago
Did u use a regular compressor? Or an electric tire compressor? Gr8 job, just wondering if I could use a small electric compressor.
lars.nijenhuis.3 9 years ago
where do you buy pistol
msw100 11 years ago
flamesami 14 years ago
seanminator 11 years ago
Eric Sandman 13 years ago
I have made my own for a pressure pot blaster so I have variable trigger flow which is hard to do. I use it to etch glass.
You can see a picture of it at http://www.sandblasterinfo.com/homemade-pab-nozzle/
Let me know if anyone wants the plans by leaving me a comment at my blog if your interested.
sophiedsouza 13 years ago
jimmy dean 13 years ago
Devrimm 13 years ago
Devrim
hbCyber 16 years ago
Technophile 14 years ago
Compressors have three main numbers:
* Maximum PSI (Pounds per Square Inch) air pressure
* CFM (Cubic Feet per Minute), how much air it will deliver at a given PSI (pressure). Often there will be a couple of CFM numbers; the higher the PSI, the lower the CFM because it takes longer to pump up a higher pressure.
* Tank volume
And then there's the quality and lifetime of the compressor.
If you're doing a few pairs of jeans, a small, cheap compressor is fine.
For larger jobs and sandblasters, you'll want more CFM (requires a bigger motor). If the compressor is too small (not enough CFM), you can still use it. You'll be able to blast for a while until the pressure drops, then have to stop and wait while the compressor chugs away building the pressure back up. Tank volume will be important here. Also look at air-hose sizing; too small of a hose will drop too much pressure.
If you're doing a lot of work, you'll want higher CFM and a compressor that will last.
Also you can balance the cost of a better sandblaster (may be more efficient) against compressor size. E.g. for air tools, the Harbor Freight tools are cheap, but waste a lot of the air. OK for a few small jobs, but if you're doing a serious amount of work go for a better brand.
Keep the compressor (and other machinery) away from the sandblasting area -- 'breathing' the abrasive dust will kill it! AND you. Your lungs won't work very well if they're full of fine sand! Wear goggles, gloves, long sleeves, spend $30-$40 on a respirator mask with P100 filters (stops 100% of particulates). A hood is nice to keep the sand out of your hair. Keep an eye on where the dust is going, too. Don't let your buddies stand around and breathe the dust!
jaysbob 16 years ago
