Introduction: Make a Bicycle Lamp Without Battery
Not long ago I got a new toy, A bicycle dynamo, want to do something with it. Make a bicycle lamp is my first idea, Many people's bicycle have lamp, but it need battery, and the battery also need charging or replacement. so now, let make a bicycle lamp without battery~Here we go!
Step 1: What Do We Need
Hardware:
- Bicycle dyname * 1
- Blue bright LED * 1
- JST 2.0 Interface * 1
- Cable * 4
Other:
- M3 Screw * 2
- M3 Nut * 2
- Cable tie
- Acrylic
Oh! you also need a bicycle~~~
Step 2: Laser Cut the Acrylic
Download the file and laser cut it.
Here's we use 3mm translucent acrylic.
Here, as the acrylic shade, translucent glow effect can be increased.
Step 3: Make the Bicycle Lamp
1, Welding cable in LED.(Here generators, regardless of positive and negative, so you can actually just wiring.)
2, Welding cable and JST 1.0 interface.
3, Install acrylic parts as bicycle lamp.
Step 4: Bicycle Lamp Assembly
Use cable tie fix the Bicycle lamp in the front.
After the completion of fixed, long tail tie will remain on the outside, if you find this annoying, perhaps trying to cut off the tail, but the tail will be cut off sharp edges, more easily scratched, so I propose to tails tied up.
Step 5: Bicycle Dynamo Assembly
Step 6: Maker It Better
Actually come to think, this lamp is mounted on the rear wheel may be more useful, hahaha ~ Hope we can play a more fun project ~
8 Comments
7 years ago
Nice!
http://i.giphy.com/3o7TKUhIDrapcDIufm.gif
Reply 7 years ago
Hahahaha~ All power comes from human’s leg~~
7 years ago
Great instructable. I remember many years ago dynamo bicycle lights were the only option for cyclists, and they suffered from two issues: Light fluctuation at low speed and no light when at rest. Wondering if there is sufficient current for a rechargeable battery pack? That would give you the best of both worlds: motion-powered steady, constant light.
Reply 7 years ago
Just put capacitors :D
Reply 7 years ago
Ha~this really a good idea!
Use this to charge the lithium battery should be able, before this I tried to use LiPo Rider (https://www.instructables.com/id/Super-Easy-DIY-a-S...) charge the battery by solar panels. After a little bit modified it should be able to use bicycle kinetic energy to recharge ~
7 years ago
~WOW!~
7 years ago
how much fluctuation in intensity do you get in the lights based on how fast you go?
with no battery pack this only works when you are moving.. correct?
Reply 7 years ago
Yes, it only works when the bicycle moving, this generated voltage of the generator is 6v, I did not measure generated current. even pushing the bicycle can be light on the LED, but before this I tried to drive two 3V laser launchers, Ineffective.
