Introduction: Make a Cassette Tape Out of Wood.,,
this is a very easy and quick project
just to keep you busy.,,,
Step 1: What You Will Need,,.
piece of wood 1 1/2 by 3 1/4 inch.,
saw.,
dremel multi tool
dremel orange dipped grinding stone
1cm chisel
glue gun (optional)
tiny bit of balsa wood (optional)
hammer or mallet
Step 2: Use the Saw,,
firstly we are going to saw the wood
to the measurements mentioned earlier
1 and 1/2 by 31/4 inch.,,
Step 3: Grab Your Dremel,,,
grab the dremel attach the orange dipped grinding stone
then make 2 grinds , (making sure the dips are semetrical)
also try not to grind to deep
you want it looking like in the pic.,,,
Step 4: Now Chisel and Mallet.,,,
get your chisel
carefuly (using a hammer or mallet))
make a straight line
connecting the 2 dips.,,,
Step 5: Glue Gun.,,,
this is optional but makes a big difference
get a small amount of balsa wood and using the chisel cut a very thin piece
now line it up with the 2 straight lines connecting the dips
get a glue gun apply a thin bit of glue and with a chisel push the balsa wood in tightly to the straight lines
(use a chisel as glue from a glue gun gets very hot).,,,
Step 6: Walla the End
and thats it
a very easy quick project
stay safe every one and happy crafting.,,,
