Make a Ferrofluid Glass Display
Intro: Make a Ferrofluid Glass Display
These are the steps required to make a ferrofluid glass display. Ferrofluid is a magnetic fluid that responds to strong magnetic fields. For this display, we will suspend ferrofluid and water in a glass, and use a magnet to interact with the fluid. Fun and easy!
I made this display at Techshop SF, visit their website here: http://techshop.ws/
STEP 1: Necessary Components
From left to right:
-Glass jar
-Strong neodynium magnet
-Light lubricating machine oil (any oil will do)
-MICR, a.k.a. magnetic ink. I ordered this online for about $10. Try searching ebay for magnetic toner refill.
-Mixing tray
-Stir stick
-Water
Total, the components cost around $25.
-Glass jar
-Mixing tray
-Stir stick
-Water
STEP 2: Make the Ferrofluid
Mix the machine oil and the magnetic ink. This is where you should play around with the ratios. Too much ink, and you end up with something too viscous to flow. Too little ink, and the mixture is not magnetic enough. I found if you mix them in roughly equal parts, it worked well for me. But play with it to get the mix you want.
Use the stir stick to ensure the oil and ink are well mixed.
STEP 3: Mix the Ferrofliud and Water Into the Jar
Put the two together in the jar. I added just a little bit of ferrofluid, and a whole lot of water. If you add too much fluid, it just all sticks together.
This is the finished product! I like to shake the jar up so there are little suspended blobs of ferrofluid, and then bring the magnet to the side of the jar. The blobs race to magnets and converge into one mass that you can move around using the magnet.
6 Comments
judas79 7 years ago
Ironious 9 years ago
Mix some oleic acid into the toner to coat it. Then instead of machine oil, use kerosene. You can get a quart bottle Coleman kerosene at a stores that sells camping equipment or buy some on Amazon. Kerosene is a very thin oil.
Manatoba 8 years ago
How much oleic acid would you suggest?
first4magnets 10 years ago
Really good attempt at homemade ferrofluid! Have you tried using different suspension liquids other than water?
hallbt 10 years ago
No, my next step is to try a stronger magnet, or maybe a thinner glass jar. I imagine a lower viscosity suspension fluid would allow the ferrofluid to flow a little better, but water is cheap and available!
Danger is my middle name 10 years ago
Wow, this is really cool!
